Fri, Nov 29, 1:35 PM CST
Subject: any way to duplicate one sides distortion to another?
7/8'sIrish ( ) posted Mon, 13 September 2004 at 11:40 PM ยท edited Fri, 29 November 2024 at 11:29 AM
Hi, I am trying to save time on face morphes for an original creature I am making. I have tried duplicating with symmetry one half of a head to make a whole head distorted both sides. It looks good out side of poser. But even though poser will accept the morphe target, when I move the dial to see the changed face, it gets all srewed up? I have tried reordering the vertices in UVMapPro but even though it will do it, it still gets munched up in poser. Any ideas? Thanks
casey_42 ( ) posted Tue, 14 September 2004 at 12:01 AM
Plus and minus react just the opposite on the other side maybe?
7/8'sIrish ( ) posted Tue, 14 September 2004 at 12:09 AM
No that does not work, but thanks for the idea anyway.
stemardue ( ) posted Tue, 14 September 2004 at 4:09 AM
Poser morph target need the same number of vertexes in the geometry for being accepted. So your new geometry (the mirror and weld thing) goes through, but... the vertex order is probably totally different from the original, so that when the dial is 0, no modification is applied and all seems ok, but as soon as you apply any, poser will try to move every vertex of its original model towards its new position given by your morph object, thus crossing all the mesh and making a mess. My suggestion: in whatever program you are working outside of poser, NEVER delete or replace any vertex/polygon/face. Only move them around. If you can do that, mirror the modifiers applied to the mesh, not the parts of the mesh.
EnglishBob ( ) posted Tue, 14 September 2004 at 5:30 AM
Attached Link: http://www.eurus.dti.ne.jp/~masasi/Service/indexE.html
Have you tried Masa's Morph Target Mirror? I have to say it rarely seems to work for me, but others report good results. You can make half a morph target, and MTM will duplicate the other half for you. Your mesh needs to be symmetrical - if you made it by mirroring in the first place, that should be ideal.
