Sun, Dec 1, 3:07 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Python problems
svdl ( ) posted Mon, 13 September 2004 at 6:03 PM · edited Tue, 26 November 2024 at 12:48 AM
Hi all, I have major trouble running Python in Vue 4 Pro (version 4.53, build 270045). All scripts fail with the message "global name GeVUEChild not defined". Sounds like an import statement got left out in VueChildFuncs.py (it's got no import statements at all) or maybe an important module got left out for one reason or another. Updating to the 4.54 beta doesn't help. From what I know of Python, there are only two additional files in PythonLib compared to a normal Python 2.2.2 installation. In what versions of Vue 4 Pro does Python run? What Vue-specific files should be in the PythonLib folder? In short, what do I have to do to get Python to work? I have contacted e-on about this issue, they haven't provided a solution yet.
My gallery   My freestuff
war2 ( ) posted Tue, 14 September 2004 at 4:56 AM
the current vue 4 pro python implementation is borked. e.on has/is working to correct the issues it does have, so i asume you can look forward to a vue 4 pro update regarding python this year. you can check the vue 4 esprit/pro user forum on the e.on website, theres a post there regarding python(to lazy to check it myself)
gilbertdid ( ) posted Tue, 14 September 2004 at 12:09 PM
Attached Link: http://www.e-onsoftware.com/Support/ShowMessage.php?id=1069710785
"the current vue 4 pro python implementation is borked"
... and they are very slow to fix python problems. I have an issue open with e-on since last november. They keep saying it will be fixed but it never gets done. e-on used to be quick for this kind of stuff but now they seem to concentrate on new versions (vue5) instead of fixing bugs in existing versions.
This is not very serious for a "pro" product
svdl ( ) posted Tue, 14 September 2004 at 1:28 PM
The 4.54 full updater solved the problem. The incremental updater does not.
bonnyclump ( ) posted Tue, 14 September 2004 at 3:44 PM
bro do I hear that? Yes.
e-on ( ) posted Wed, 15 September 2004 at 11:01 AM
Gilbertdid, the python "problem" you are referring to is a result of an improvement you requested (the ability to set materials for groups). Feature or fix requests have to be prioritized according to gravity and the number of people who demand them. I'm sorry that it took so long to implement properly the feature you requested, but you should keep in mind that this feature has been added for you. Also, as Tom from tech support told you, it will be in the upcoming release 4.54. So you see, we don't "only" concentrate on new versions ;-) Enjoy!
