The right thigh works fine otherwise. This only happens when rotating the body or hip on the y-axis. Nothing strange happens when rotating on the x or z-axis. The character is essentially the P4 female. I've been adding a couple morphs to it and I played with the joint parameters a bit to try to get rid of the crumpling the sometimes happes. I checked in CR2 Editer and the thigh is still parented to the hip. Where do I find the level number? Thanks.
Actually, I thought the joint parameters got messed up, too. I dug up an earlier version that had the joint changes done to it and it was fine at first. Then used CR2Editer (1.51) to try and compare it to the one that was messed up. Didn't make or save any changes. Then I used Morphmanager to copy some of the morphs from the messed up one to the older version and saved it as a new file. (No morphs were added to the thighs or hip.) Then I opened the new file I made and it had the problem. Then I opened the file that was good and now that had the problem too. I've already started over and so far the problem hasn't come back.
