Sat, Nov 23, 2:55 PM CST
Subject: Need help to find a way to export from 3DS to Poser.
Black_Star ( ) posted Mon, 01 November 2004 at 5:49 AM · edited Sat, 23 November 2024 at 11:57 AM
Hy there! My question is simple : how do I export multiple models from 3D Studio Max to Poser?I know is really simple , but what I am interested is this : I have three boxes in 3D Studio Max , each of different sizes and I export them separately (each at a time , all are in the same scene) as .3ds or as .obj (the result is the same for what I am interested in) and import them all in one Poser scene.Whell , the result is overwhelming : I import three different size on two dimension boxes and I obtain in Poser three different on all three dimension boxes.Let's say they have : 1x1x0.1 , 2x1x0.1 and 3x0.5x0.1 (take note of the width of 0.1 wich is the same at all three).Whell , imported into Poser you get something like : 3x3x0.3 , 3x1.5x0.15 , 3x0.5x0.1 (all sizes are abstract , I know that Poser and 3D Studio Max have different unit systems).So , as you can see , all are relative to the highest dimension of the first imported , wich means all other dimensions are modified relative to this one.Take for example all the widths , wich are now different , altough they must to remain the same... You will say : resize them.Ok , I will do that with three boxes , wich means a lot of time to discover the proportions between them and set up a common unit system.But if there are 20 boxes?Or maybe one hundred? I know there is a way to do this better , and there is something small that escapes me.I also have Max2Obj plug-in but has not solved this problem.Maybe I am not using the right parameters?Do you use it?Wich are the parameters you use in order to correct this? Is there any other method? Best regards!
Tyger_purr ( ) posted Mon, 01 November 2004 at 8:53 AM · edited Mon, 01 November 2004 at 8:54 AM
when you import the 3ds into poser, there is a dialog box that pops up with some check boxes.
uncheck the box that says "Percent of standard figure size"
this option is to resize your items to a percentage of poser standard figure size. so if you have 3 diffrent size boxes and tell it to import each to 100% of standard figure size they will all come in with one dimension the same and the other scaled up relative to their size. Poser Reference manual page 87
Message edited on: 11/01/2004 08:54
My Homepage - Free stuff and Galleries
kawecki ( ) posted Mon, 01 November 2004 at 10:38 AM
Export from 3dsMax as obj with the scale factor option as 0.001, then import the obj with Poser with all options unchecked.
Stupidity also evolves!
