Sun, Dec 1, 3:00 PM CST
Subject: Blonde Ponytail
AceC ( ) posted Tue, 02 November 2004 at 12:53 AM · edited Fri, 29 November 2024 at 11:27 AM
Hi, I'm looking for either a blonde texture for Kozaburo's original ponytail mesh, or a prop/figure of a simple pulled-back ponytail. Does anybody know where I could find something like this?
Saro ( ) posted Tue, 02 November 2004 at 2:04 AM
Do you have anything like Photoshop or a painting program? That way you can just make a copy of the hair texture and re-color it. I do that a lot, and its a good method.
ENGELKEN ( ) posted Tue, 02 November 2004 at 7:35 AM
Koz's Pony Tail (the newer one) is blonde. If you're committed to the older Pony Tail, then you can probably remap that one with the Koz's blond textures.
cedarwolf ( ) posted Tue, 02 November 2004 at 9:23 AM
I just go into the materials room and change the material color...seems to work just fine...
AceC ( ) posted Tue, 02 November 2004 at 10:22 AM
@Engelken: Koz's new ponytail has a significantly different look to it. It's very short, and looks pretty styled (unless there are some morphs that I'm missing). It just doesn't look quite right on the male character I'm working on. So far as remapping... I hadn't thought of changing the UV Map. I'll see if I can get it to be somewhat close to the layout on the new ponytail. @Saro, Cedarwolf: That's what I've been doing... Unfortunately, because the color was originally black, there are large spots with no detail. You can't see them in black hair, but they really show up in light color hair.
wheatpenny ( ) posted Tue, 02 November 2004 at 12:46 PM
Site Admin
There's a male ponytail that comes with P4. Too bad nobody ever made any textures/transmaps for that one...
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
ENGELKEN ( ) posted Tue, 02 November 2004 at 9:16 PM
Yup, you are right about how different the two maps are. This was way harder than I thought it would be, but do-able.
AceC ( ) posted Tue, 02 November 2004 at 10:49 PM
... I don't suppose you could post that online somewhere, and save a poor student a bit of time? :-P It looks great. Was that accomplished by changing the UV Map or manipulating the image texture? Is the donor texture Koz's other ponytail, or did you use a different source?
ENGELKEN ( ) posted Wed, 03 November 2004 at 7:44 AM
Attached Link: http://http://7parabian.com/PonyTail.html
Thank you. Put them on the linked site. You can download from there. Also made a more toned-down blond version, shown here.
ENGELKEN ( ) posted Wed, 03 November 2004 at 7:47 AM
Attached Link: http://7parabian.com/PonyTail.html
Sorry about that....just too early in the morning. Here's the proper link.
And in answer to your question--how it was done--took Master Koz's blond texture and cut and pasted pieces till it looked right.
AceC ( ) posted Wed, 03 November 2004 at 3:16 PM
Perfect... Thanks a ton.
