I've had no issues with this outfit but I have had similar things happen with other stuff. I've clothed a figure and then posed it and the outfit does something weird. I do a conform again and it goes back how it should. Try conforming the pants again after you've posed him and see if that works.
Injustice will be avenged.
Cofiwch Dryweryn.
Once in a while you'll hit a conflict in the computing and an odd extreme bulge or distortion will appear. Something about the factors of the number being identical (it's beyond my math skills). The fix for this is to adjust the joint parameter one or two degrees at a time until the bulge disappears. Sometimes it takes as little as a fraction of a degree.
I have posed M3 in a crouching position and when I try to conform his pants there is some strange flap going straight up. Does anyone know if there is a problem with these pants?
