Fri, Nov 29, 11:57 AM CST
Subject: Disabled textures in Poser 4's materials dialog
Jimdoria ( ) posted Sat, 20 November 2004 at 10:17 PM · edited Mon, 25 November 2024 at 10:18 PM
Hi everyone -
This is probably something simple, but I can't seem to find the answer anywhere online. Hoping someone can help me out. I'm creating a series of custom textures in JPEG format, using the P4 for PC Materials dialog to apply them.
The problem is that after I load and apply the texture, the filename of the texture map becomes disabled in the Texture Map list, and I can no longer select it.
The texture renders fine. As long as I leave it selected, everything's OK. But if I want to change it and change it back (i.e. I apply a MAT pose then need to re-apply the texture) I cannot, since I'm unable to select it from the list. If I try to re-load it, Poser gives me an error message saying the texture is already loaded. Even after saving the file out, closing Poser, and re-loading the PZ3, the texture still appears as disabled in the list.
What can cause a texture in this list to become disabled? Any idea how I can work around this? Thanks.
  • Jimdoria  ~@>@
Little_Dragon ( ) posted Sun, 21 November 2004 at 2:28 AM · edited Sun, 21 November 2004 at 2:28 AM
What's the filename of the texture? Poser 4 behaves rather oddly if certain special characters (left parentheses, for instance) are in the name.
Message edited on: 11/21/2004 02:28
