Actually, once you've created the new picture textures and imported them into Bryce, you can export them as .mat files. If you click on the little triangle next to EDIT, the materials palate opens. Go to the section called "User" and you will see across the bottom "Add Delete Import Export." Once you've created a texture, use "Add" to add it to the User palate. Then click on it and hit "Export" to create a .mat file from it. "Import" lets you add other .mat files, such as downloaded ones.
does anyone know what program to use to create Bryce materials?
