Fri, Nov 29, 11:27 AM CST
Subject: How to Turn off render on a prop in a scene?
camelot77 ( ) posted Thu, 30 December 2004 at 12:37 AM ยท edited Tue, 26 November 2024 at 12:50 AM
is it possible to make an object not get rendered in a scene but still be visible? I have an object in a scene that looks better unrendered.
Kelderek ( ) posted Thu, 30 December 2004 at 2:31 AM
I don't think it's possible for the rendering engine to skip an object that is visible. However, you can set the surface properties so that the rendering engine will do very little. No texture, a plain color, no highlights etc.
camelot77 ( ) posted Thu, 30 December 2004 at 5:32 AM
Thanks I tried that but it does'nt work, thanks for the help though :)
xantor ( ) posted Thu, 30 December 2004 at 5:41 AM
It might help to show the object rendered and unrendered so people may be able to see what can be done.
ENGELKEN ( ) posted Thu, 30 December 2004 at 7:24 AM
export two images, one rendered in jpg, tif, or whatever, and the second, go to hierarchy and put all the other scene elements invisible, except the one you want and export this, unrendered, as a .png. It will give you an image to layer over the first.
eng
geep ( ) posted Thu, 30 December 2004 at 9:10 AM
Hi camelot77,
You might try this ...
  1. Hide everything except the unrendered object.
  2. "Paste onto Background."
  3. Hide the unrendered object.
  4. Render (everything else) over Background image.
Or, do it in the reverse order if required for the unrendered object to be in the foreground.
Note - You don't want to move the camera between shots, obviously. ;=]
Holiday cheers,
from dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 30 December 2004 at 9:12 AM
How-some-ever ... That raises a question ... (in my tiny li'l brain, anyway) What are you doing that makes an object look better UN-rendered? HmmmmmMMMMM??? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
SirLancelot ( ) posted Thu, 30 December 2004 at 6:50 PM
Thanks for all the support hear, its nice to hear from you Geep :) the paste background thing is a pretty good idea but it would be a neat feature to see on Poser6 to have the option of not rendering certain objects in a scene, would be good for creating scenes especially, happy new year everyone.
xantor ( ) posted Thu, 30 December 2004 at 8:03 PM
"What are you doing that makes an object look better UN-rendered?" That was why I asked to see the rendered and unrendered versions of the scene. It could be the problem with rounded polygons when you have to do the spit vertices thing with uvmapper to make them look right. They sometimes look worse when rendered.
SirLancelot ( ) posted Fri, 31 December 2004 at 5:10 AM
It does'nt seem to make a difference since it does'nt seem presently possible within poser.
