Blender F.A.Q (Last Updated: 2024 Nov 17 9:25 pm)
depends on which type youre talking about.
Image based UV mapped textures, yeah sure no problem. Just set it up in blenders material room.
example: in mat room. click add new texture. name it. select map input>UV. select map to>col.
Click the texture button (f6). select Image from the type drop down. Click Load Image and use the file requestor to find your image map.
Poser5 procedural textures? No. at least not that I know of. A python would have to be writtin to do that I think.
did you try importing the poser model to blender?....then go to Runtimetextures inside the poser folder all i have is daz studio but i know the poser made model textures are in their C:Program FilesDAZStudiocontentRuntimetextures So some were in side the poser runtime folder should be a texture folder find that then use the blender material editor to add a new material you need to have the model imported to blender first then in the material editor click the texture button (f6) click add new were it says texture type change none to image were it says load image browse to the poser runtime texture folder find you're texture then click select image in the pannel i hope that helps some
jpgs can easily be used add a material to your object then add an texture to that material go to the texture menu and choose load picture there and direct to the folder on your harddrive.
for
some free stuff i made
and
for almost daily fotos
Okay. i take it from this thread that i may....
1. Import a Poser figure/s as a UV mapped and exported obj file straight into Blender?
2. I can extract the associated jpg textures from that Poser figure/s with 'TEXTRACT' utility to save them in my Blender project folder.
3. Import those jpg's as new textures into my Blender project to apply straight to my imported obj figure?
Cos that's the way I've been working with Cinema XL so far. If the process is as i've stated above then Blender has no trouble importing characters and props from Poser.
Well, is there a way of importing Poser materials to Blender? Most free stuff here is in Poser format ;) Any feedback welcome.
