Sat, Nov 30, 3:48 PM CST
Subject: CANNOT EXPORT AS OBJ WITH POSER5
TIMMYLYNN ( ) posted Mon, 17 January 2005 at 3:04 PM ยท edited Sat, 30 November 2024 at 3:31 PM
Hi,
i am trying to export a morphed character and i get as far as checking the save with polygon groups and it appears to save it. I can delete the character from the scene but most of the options in the menu are greyed out.....i have to x to get out. then there is no file...i found a post about it and the solution was to reinstall poser.......can i reinstall on a different computer? and what about the things i saved like i thought i had made my own characters, i had just hit the + button in a new character libary....does that make a new character? or if i mess with the cr2 will it mess up the original character? I was under the impression that i need to export the new character as obj...then import it and go to the hierarchy editor and press create new Figure....it that correct?
Any input appreciated.
TimmyLynn
Message edited on: 01/17/2005 15:06
geep ( ) posted Mon, 17 January 2005 at 3:16 PM
Hmmm ... You might want to [ CHECK THIS OUT.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1649633) cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
TIMMYLYNN ( ) posted Mon, 17 January 2005 at 4:00 PM ยท edited Mon, 17 January 2005 at 4:01 PM
Thats what i was using Dr Geep and poser5 will not let me export as obj....it just basically locks up....when i x out if asked if i want to save the current pzz file which is the whole scene right????but it will not let me go to say File Exit....i have to hit the red windows x you know....
Message edited on: 01/17/2005 16:01
TIMMYLYNN ( ) posted Mon, 17 January 2005 at 4:10 PM
Remember Im using POSER5 which I love....i hate the idea of reinstalling...it sounds very scary...would i lose everything i have added like m3 v3 and aiko?? mil dog and props and have to reinstall all of that again to....please tell me it isn't so...i first noticed this a while back when i was trying to export to obj for work in amorphium ....i can import the cr2 poser objs into amorphium but i cannot export period to obj from Poser 5........Help Dr Geep please tell me i don't have to reinstall....even though i did get a better computer...can i install poser on it or do i have to pay for it again to do that? and yes the system it is currently on has plenty of space...that was mentioned in the other thread....they never got a solution...i did a search under 'cannot export obj' in poser forum.......
geep ( ) posted Mon, 17 January 2005 at 4:10 PM
What do you have selected when you try to export? What version do you have installed? Mac or PC? ;=?
cheers,
dr geep ... :o]
edited 10/5/2019
randym77 ( ) posted Mon, 17 January 2005 at 5:13 PM
I have this problem, too. If the problem is grayed out boxes, try right-clicking on the time in the bottom right corner of your screen. The Windows clock. A menu will come up. Choose Adjust date and time, then click OK (without making any actual changes). The grayed-out boxes won't be grayed-out anymore. Yes, it's weird, but it works!
markschum ( ) posted Mon, 17 January 2005 at 5:23 PM
You have One lisence for Poser 5. You can install it on any computer that suits you but you must remove it from the other. You should be able to exit Poser by using the File exit command. If that is greyed out are you sure that the file export is complete. Exporting the geometry for a modified figure may take several minutes. When you export keep an eye on the drive light and wait for it to stop or open windows explorer and check that the file has been written out. You should not lose the contents of the libraries by doing a new install but it might be a good idea to rename the original runtime folder, reinstall poser and then putting the stuff you have created back. If you are changing thing in the cr2 files it is always a good idea to work on a copy. That way you always have the original if you mess it up.
TIMMYLYNN ( ) posted Tue, 18 January 2005 at 6:33 PM
I have body selected.......it is PC lasted patch v 5.0.4.325 wasn't that the last patch? poser5 adn randym77 are you able to export or does it just grey out.....this may be why the fix for the mihai hair is not working for me in the firefly renderer....i followed every step to the T and it still doesn't work....maybe that's because it isn't exporting the hair after i group it....this is weird.....Dr Geep please tell me I don't have to reinstall......i was doing your robox tut and ran into the export problem again......i have modified my interface which i don't want to have to do again.......also i removed that content paradise room......any suggestions anyone.....Help
TIMMYLYNN ( ) posted Tue, 18 January 2005 at 6:51 PM
ok let me see if i can be a little more detailed.......i am try to export a morphed figure i have been working on as an obj so i can then import it and create a new figure.....isn't that the procedure Dr Geep?....then i can alter the cr2 of that new figure without worrying about messing up the original characters cr2.......i have a cr2 of my new character but it shows the original characters name in the text editor???? anyway so i load my morphed figure into poser 5 pose room.....i hit file export wavefront obj..........on the parameter dail the figure is selected .....then the hiearchy window opens i uncheck universe which unchecks everything and check figure which checks all body parts and hit ok....then window comes up and asked for name of obj....then i type in name and hit save......then 6 box window pops open on which i choose include existing polygons and polygon groups only and hit ok ....then nothing happens there is no noise from my disk drive like nothing is happening and everthing is greyed out except the help options and the animation options...i tried the system clock thing and that does nothing for me....again when i hit the red x in the upper right hand corner which appears to be the only way i can exit poser5 at this point it asked if i want to save the current pzz...which i answer no and it closed the program down....
randym77 ( ) posted Tue, 18 January 2005 at 10:56 PM
I've had the problem of not being able to save OBJs from time to time. In my case, it looks like it's saving properly, but the OBJ file is not created. I'm not really sure what causes it. It may be a memory thing, because closing down Poser, then opening it again sometimes fixes it. Never had all of Poser grayed out, though. You may want to try re-installing. It's not that big a deal. I've done it several times. (Poser does tend to go corrupt now and then.) Rre-installing didn't mess up my runtimes or anything. Just install it on top the existing installation. If you're really paranoid, you can back up your runtimes to CD or DVD first. Probably a good idea to do that anyway.
geep ( ) posted Wed, 19 January 2005 at 8:09 AM
Hi TIMMYLYNN, I am sorry but I have not been able to duplicate the problem that you describe. It appears that you are doing everything properly so the only thing I can suggest (gulp) is to re-install Poser. It is not that difficult ... as randym77 says. Sorry I can't be of more help. cheers, (anyway) ;=[ dr geep ;=] P.S. Try turning file compression OFF. Just a thought. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
TIMMYLYNN ( ) posted Wed, 19 January 2005 at 5:11 PM
Thanks Doc that did it....now im trying to get my UI back the way i had it.....i forgot how to make the doc style and editing tools vertical instead of horizontal....does anyone remember..... thanks again,,, TimmyLynn
geep ( ) posted Wed, 19 January 2005 at 5:49 PM ยท edited Wed, 19 January 2005 at 5:51 PM
Alt + "click" on the tools (P5)
Alt + "click" on the title (or the tools) (P4)
Message edited on: 01/19/2005 17:51
cheers,
dr geep ... :o]
edited 10/5/2019
TIMMYLYNN ( ) posted Thu, 20 January 2005 at 1:21 AM
Thanks Doc Your the coolest.......
