Thu, Feb 27, 6:57 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Deleting all Frames with Python
Ralf61 ( ) posted Thu, 20 January 2005 at 11:50 AM · edited Thu, 27 February 2025 at 2:50 AM
Can somebody gmme a short hint how to delete all Frames within Python? There is a command 'DeleteAllKeyFrames' but this is not what I'm looking for. I need to erase all frames (of course not the first one :-) Thanks in forward
ockham ( ) posted Thu, 20 January 2005 at 1:12 PM
Ralf61 ( ) posted Thu, 20 January 2005 at 2:41 PM
Am I blind or did I miss something? :-) I can'T find a command to delete a frame in your useful code. Only for Keyframes. Sorry that I have to ask again ...
Ralf61 ( ) posted Thu, 20 January 2005 at 2:48 PM
I assume that I should use something like poser.Scene().NumFrames() = 1 But this doesn't work. OR should I use SetOutputRange. But this isn't exactly what I'm looking for ... sigh
ockham ( ) posted Thu, 20 January 2005 at 4:33 PM
Sorry, I thought you meant keyframes. In order to delete (or add) actual frames, Python has to play a trick, which only works when there's a figure in the scene. The attached file holds an example of Fake Frames. The little code at the bottom is just to test the main routine; you would include the routine in your own code and call it in the same way.
My python page
My ShareCG freebies
Ralf61 ( ) posted Thu, 20 January 2005 at 4:41 PM
Thank you again. Thats what I needed! I always wonder how some people find such a solution. Great!
underdog ( ) posted Mon, 24 January 2005 at 6:12 PM · edited Mon, 24 January 2005 at 6:15 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1854359
Thanks Ockham. That's a neat trick. I knew that adding frames was going to work, but finding the way to delete frames is a great tool to have around.
Ah, there it is... I thought I had asked about this months ago.. It was back in July. Good things come to those that wait.
Message edited on: 01/24/2005 18:15
3dtrue ( ) posted Fri, 22 April 2005 at 2:06 AM
wow! thanks ockham. you rock! i love how the Poser PDF manual never bothers to tell you there is not a call to add/delete the total number of frames. I've been stabbing for a solution and here it is. thanks again.
