Sun, Dec 1, 3:12 PM CST
Subject: Aiko's head on V3 body
Great Bizarro ( ) posted Wed, 12 January 2005 at 8:07 AM · edited Fri, 29 November 2024 at 12:51 PM
Can someone graft Aiko's head to Victoria 3's body. Would open up a lot more clothing and accessories for her.
SWAMP ( ) posted Wed, 12 January 2005 at 8:51 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2068674
Well the Aiko full pack comes with a figure that takes all of StephSP clothes,etc.so that gives you more options. Or you can follow nakmuram's very good mini tut to get an idea of how to put the Aiko head shape morph into Vick's head. His tut is how to put Steph's head (morph) on Aiko,but the process is the same (link). SWAMP
Great Bizarro ( ) posted Wed, 12 January 2005 at 10:08 AM
Did a search after posting and found the thread you mentioned, worked great. Here she is Aiko V3 with Wyrmmaster mags.
usslopez ( ) posted Wed, 12 January 2005 at 10:19 AM
She almost looks like Tyra Banks!
My RMP Store ; My Free Stuff
SWAMP ( ) posted Wed, 12 January 2005 at 10:54 AM · edited Wed, 12 January 2005 at 10:58 AM
That's great it worked for you.
Now what you might want to do (if you have the Aiko morph pack)is to transfer the Aiko inj/rem head morphs to your new figure using MorphManager.
Of course you can use the Vic3 inj/rem head morphs (as this is still Vicky),but some will give very odd results when applied to the different head shape.
Have fun,SWAMP
Message edited on: 01/12/2005 10:58
mamba-negra ( ) posted Wed, 12 January 2005 at 1:23 PM
Someone over at PowerPros had a Steph->Vicky head morphs that would make stephanie look just like vicky (headwise). Then, any morphs you injected to steph would have the same effect as they did on Vicky. You could probably do the same thing. You'll have to dig for the message, but do a search on messages by mamba-negra (I started the message by trying to stick Vickies head on steph's body) eric
nakamuram ( ) posted Wed, 12 January 2005 at 8:44 PM
I love your Victoraiko!!! What offset values did you use? I'm thinking of making Aikotoria...
TigerD ( ) posted Wed, 12 January 2005 at 8:46 PM
I tried doing this and V3's head disappeared into her body. As V3 is taller than Aiko. If you raise Aiko's body so that her head lines up with Vicky's first before creating the obj's the morphs work fine.
Great Bizarro ( ) posted Wed, 12 January 2005 at 8:51 PM
You need to scale up Aiko then adjust the scale of the neck to near the size of V3's where they connect at the base of the neck. Also adjust the z axis.
nakamuram ( ) posted Wed, 12 January 2005 at 10:57 PM
That won't work. Scaling is not preserved when exporting .obj files.
FyreSpiryt ( ) posted Thu, 13 January 2005 at 6:56 PM
I think scaling is preserved if "export as morph target" is NOT checked. IIRC, That option ignores scaling and positioning; I think it was put in for people who wanted to export a chunk of a figure to take it into another program for morphing.
nakamuram ( ) posted Thu, 13 January 2005 at 7:49 PM
I'll give it another try. Maybe things have changed from P4 to P5.
TigerD ( ) posted Wed, 26 January 2005 at 2:06 PM
I didn't scale Aiko. I just moved her so that her head was level with Vickys.
nakamuram ( ) posted Wed, 26 January 2005 at 7:53 PM
Last night, I put V3's head on Aiko's Body -- Aikotoria!! Check it out on my "tutorial" thread. Not bad for a totally free "Playboy" type character. The join between V3's head and Aiko's neck is a lot smoother than the one between SP3's head and Aiko's neck.
