Sat, Nov 23, 2:33 PM CST
Subject: need help with putting poser characters into bryce
angelus_ ( ) posted Tue, 09 January 2001 at 8:49 AM ยท edited Sat, 23 November 2024 at 12:14 PM
Hi, I've been trying to add a poser character with clothes that use transparency into bryce. I tried putting all the files into one folder but that didn't work. I was wondering if there is a tutorial with pictures that shows how do it
Prizm Break ( ) posted Tue, 09 January 2001 at 9:11 AM
Export the poser and all the clothes as .obj. Then in Bryce hit file/import object and lead it to the directory you exported to. Does this help? You can do the transparency in Bryce
KenS ( ) posted Tue, 09 January 2001 at 1:01 PM
In the Materials Lab, select the small arrow at the top of the screen to open the Shading Mode menu, Select Blend Transperancy. In the OPTICS section of the Material Lab, check the 2nd dot next to transperancy and set the component to picture(Click the "P"), import your transmaps into the Picture Editor, load your map into the first box, then click copy, goto the 2nd window(where bump maps go) and click paste, click ok to delete current selection. Click the Exit checkmark and return to the Materials Lab. This process will have to be repeated for each body part the tansperancy map is applied to.
angelus_ ( ) posted Tue, 09 January 2001 at 1:57 PM
thanks for the info but is there a tutorial on the web with pictures as a guide?
thgeisel ( ) posted Tue, 09 January 2001 at 2:06 PM
goto www.brycetech.com .They had a good tut with pictures there. or look in the tutorial sektion in this forum, there should be a tut "importing vicky in bryce" in which the transmaps are described
dcrich ( ) posted Tue, 09 January 2001 at 5:09 PM
Attached Link: http://www.brycetech.com/tutor/bryce/brycealive.html
the actual url of the step-by-step thing with poser is: http://www.brycetech.com/tutor/bryce/brycealive.html go pictures for the steps AND if you are still confused there are flash files that will actually walk you all the way thru... luck BT
dcrich ( ) posted Tue, 09 January 2001 at 5:11 PM
Attached Link: http://www.brycetech.com/picts/tutpict2/Hairdemo4.jpg
lol..somebody moved my keys again... should say "got" not "go".. BT
angelus_ ( ) posted Wed, 10 January 2001 at 4:22 AM
thanks for the link angelus
inyerface ( ) posted Thu, 11 January 2001 at 1:23 AM
Attached Link: http://lightning.prohosting.com/~maccastl/401.html
in case of a wierd memory problem...
wal ( ) posted Fri, 12 January 2001 at 5:37 AM
Don't hope too much for that, alexadh. I'm not a programmer and know both apps only as a user. But from how they are "feel", from the GUI and more, I suppose that Bryce and Poser are very different in vital key aspects. To put them together the codes for both apps had to be written entirely new from scratch. Corel and Curios Labs can't do that at the moment. Instead we should hope that both can launch Version 5 of their product very soon. - wal
