I think thats the point. you tried with a koz hair which was a .cr2 hair. theres no problem, because cr2 can take matposes without problems. aila hair by DAZ is a .hr2. (a prop). and props only takes matposes if they are parented to a figure. so you cannot use matposes at a hair which is load without a figure. if you load the figure first, and then the .hr2 hair it is parented und you can change the colour with matposes. :)
Â
Â
Turn your face to the sky... and the shadows will fall behind you...
I just tried out the Aila hair on Jessi and all MATposes in the set work fine without problems. (Im working on a PC)
I just tried out and loaded the Aila hair and the MATposes from my second runtime and all works fine.
MAT files for hair work fine if the figure and the hair prop is active in the document window (example: Figure 1, AilaHair).
If the document window has another figure (clothing) selected with the hair prop (example: HD_Pants, AilaHair) MAT files will not work on the hair prop.
If you are in the Pose room and you select the hair prop, the figure to which it belongs is also selected. But in P6 - if you have the material room open - you can select a prop with the colorpicker. The material settings will show for the hair and the prop will be selected in the document window - but NOT the figure to which it is parented. And conseqeuntly the MAT files do not work.
So the solution is simple - select the hair prop in the document window and MAT files for the hair will work
Im working with win 2000 - and all works fine. But I have not the possibility to try with XP.
I've run into a bug.
Daz hair MATs are not working in P6
Example:
I load AilaHair.
I apply the AilaHair 05 MAT.
No change in hair color.
I've tried several hair models (Flip-Do, Cuffed Tail etc...) and am getting the same thing.
Koz's hair accepts MAT changes fine.
