Sat, Nov 23, 7:53 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Bending Rope - Ideas Please
AndyCLon ( ) posted Wed, 30 March 2005 at 6:00 PM · edited Fri, 26 July 2024 at 8:42 PM
Attached Link: Flea Circus - Flea on tightrope
I am modelling a unicycle on a tightrope and have been using Cognito to control the motion via a rack, rocker, gear and cam.
However, I want to rope to dip at the same time as the movement of the cycle.
I tried using Akira Kurozuka's Potentializer but this did not seem to work. I could not perswade the 0 and 100% animation settings to take and I'm not actually sure it would produce quite the right effect.
So does anyone have any suggestions?
Thanks, Andy
http://www.fleacircus.co.uk
kelley ( ) posted Wed, 30 March 2005 at 9:17 PM
What about a very thin cylinder in the Spline Modeler with only three cross-sections? You could slide the center cross-section back and forth along the rope and pull it downwards to match wherever the unicycle is at any particular frame.
noviski ( ) posted Wed, 30 March 2005 at 9:19 PM
Well, in this case, first I create the rope with morphs, just like the animation as you need. Then I put the cycle using the motion path as the same animation of the rope. Sorry about my English, Andy. I dont know if I could express myself, but I rope, oops, hope you can catch the idea. ;-)
noviski ( ) posted Wed, 30 March 2005 at 10:12 PM · edited Wed, 30 March 2005 at 10:12 PM
Try this, Andy. A mix of my and kelleys suggestion. Just change the extension of the rope.txt to rope.car (I use Carrara 4).
Message edited on: 03/30/2005 22:12
AndyCLon ( ) posted Thu, 31 March 2005 at 12:24 AM
I had been thinking along similar lines myself but was hoping that there might be a way of linking it all together. Currently all of the behaviour of the unicycle is controlled by a single parameter. I just change the "motor" and the rest of the behaviour is linked in. I suppose I will just have to animate the rope by hand to match the cycle. Your example will be of great help.
Thanks for the feedback
kelley ( ) posted Thu, 31 March 2005 at 9:21 AM
I'm not familiar with Cognito, [nor have I used morphs, for that matter] but if you made the rope the 'parent' and the unicycle the 'child', it should follow the rope no matter where you pull it.
Nicholas86 ( ) posted Thu, 31 March 2005 at 8:27 PM
You could also use potentializer and have it track alongside the unicycle. Brian
