C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Better! :) IBL is definitely not an end-all of lighting in Poser. Remember that it is not HDRI, which actually contains extra-color information and uses it to get more realistic lighting. So far, I've found that complementing the IBL light with an infinite or point light at the same position as the greater light source (which, I'm guessing coincides with the IBL light direction (?)) compliments by adding the contrast, highlights that IBL seems to remove. So, although additional lights ideally decrease IBL usefulness, I think that they are a necessity. Think of IBL as the HDRI ambient color information and the other lights as pseudo HDRI luminance information.
off.
-- Bjarne
Stroustrup
Thanks :) You are right. I reach the same conclusion about positioning the lights in IBL mode. I have also discovered that additional (not IBL) lights don't create shadows when IBL is on (I am not sure if it is a real discovery or I simply missed something reading the manual). I use position of IBL light for creation of shadows and - of course - so as to create proper highlights the infinite light has to be in the same position. Despite wrong assumptions - infinite for shadows, I get the proper result - infinite for highlights. After 2 year break in working with Poser and after moving directly from P4 to P6 I consider P6 possibilities as really amazing. Thank you for your comments
Ah. I was thinking Spain. :)
off.
-- Bjarne
Stroustrup
