Sun, Dec 1, 3:10 PM CST
Subject: P4femadvanced
D0GG0D ( ) posted Wed, 24 January 2001 at 3:08 PM ยท edited Sun, 01 December 2024 at 3:10 PM
It has been awhile since I loaded Black Canary and I downloaded another file "molina" that uses the p4femadvanced.obj My problem is that both do not work now. I re-installed using my old BC download and Mover101 but, still get the message can not open may need more memory. The MOVER extracts fine and the OBJ is in the right directory. I can open several other files that I am sure use more memory than this one. I can also open the OBJ by importing it and it loads fine. Can someone help me out please?
JeffH ( ) posted Wed, 24 January 2001 at 3:21 PM
It's possible that the "p4femadvanced.rsr" is corrupt. You'll find it in the same folder with the OBJ. Delete the .rsr and let Poser rebuild it next time you load that figure.
D0GG0D ( ) posted Wed, 24 January 2001 at 3:58 PM
That was it thanks.
leeroy5 ( ) posted Thu, 25 January 2001 at 11:57 AM
if you use travlers eve3 ore yarps new eve you can use the same texture as the normal p4 only for the labiaarea you net a a new texture. on travlers morphworld give jager a lot of them an you must only chance the skincolor
