Thu, Feb 27, 6:06 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
Subject: Poser will not render my animations! :(
A_ ( ) posted Sat, 16 April 2005 at 5:45 AM · edited Thu, 27 February 2025 at 2:09 AM
Hi all,
I have a problem - Poser will not render any movie files for me.
I made several animations which my Poser 4 could not render. I thought that maybe it was because of the length of the animations, or too many lights and textures for my PC to handle.
so I rendered the animations as image files, and tried to join them in a movie editing program (which gave me trouble in itself, but that's a whole differnt thread).
anyway
I decided to try and render a really simple animation to see if Poser can render that.
I made a 30 frames animations of a moving ball - default lihgts, no textures, not even a ground to cast shadows on.
and Poser did not render that as a movie. :(
I have both P4 and P6 installed.
all of my non-rendered animations problem happened with Poser 4. so I decided to try and render that simple ball animation in Poser 6.
still didn't render.
Only difference between the 2 is this:
P4 simply doesn't render. when I hit the "ok" button in the "make movie" box, it will direct me to save the AVI file, and after I hit "save", it will then do nothing. that's it. will not render, will not crash. just sort of... be there. btw, when i do ctrl+alt+del, Poser 4 is listed there as "running".
in Poser6, however, I get an error message. I hit the "make movie" button, select a folder to save my file in, press "save" and get the error I attached here, and when I press "ok" Poser simply shuts down.
anyone knows what's going on and how i can fix this?
xantor ( ) posted Sat, 16 April 2005 at 6:32 AM
Did rendering animations work before you installed poser 6?
svdl ( ) posted Sat, 16 April 2005 at 8:08 AM · edited Sat, 16 April 2005 at 8:09 AM
Could it be a codec problem? I've rendered pretty complex animations in P5 using DivX and MS MPEG4-V2, that works fine. The renders crashed when I tried the default codec. Some grammar/spelling errors edited out.
Message edited on: 04/16/2005 08:09
My gallery   My freestuff
A_ ( ) posted Sat, 16 April 2005 at 10:36 AM
well, i haven't done any animation is a really long time... and i started again around the time i got Poser 6. all the animations i did all this time ago (i.e, before iinstaled P6) rendered as AVI just fine. how can i see if this is a codec problem?
operaguy ( ) posted Sat, 16 April 2005 at 11:58 AM · edited Sat, 16 April 2005 at 11:59 AM
easy way to test if it is codec is to render the 30 frames out to individual files, even if you are not going to assemble them into a vid.
If you render out to JPG or TIF etc., it's probably a codec issue.
::::: Opera :::::
Message edited on: 04/16/2005 11:59
shedofjoy ( ) posted Sat, 16 April 2005 at 6:34 PM
I have made several test movies (one is 120 frames) in the basic render window style in Avi in Poser6 and had no problems what so ever... sounds like you may have a codec issue, try saving the animation as images and joining together in some movie editing software, or try another avi codec to see if that corrects the issues.
Getting old and still making "art" without soiling myself, now that's success.
A_ ( ) posted Sun, 17 April 2005 at 3:19 AM
ok. it must be a codec thing then, becuase: a) I can render images. b) I have a problem producing an AVI file in the movie editing software that I have. so....... what do I do?
operaguy ( ) posted Sun, 17 April 2005 at 3:56 AM
Here's one suggestiion, A_ render to individual TIF images Purchase Quicktime Pro for mac or PC ($29.99) at www.apple.com I can post a short description of the process of making a vid from individuals. I use this sequence all the time. If you don't want to use Quicktime, chose a different software to assemble/edit frames. It is a MUCH better plan to render to frames and the assemble, for many reasons. Let me know if you want help with Quicktime. ::::: Opera :::::
A_ ( ) posted Sun, 17 April 2005 at 4:02 AM
thanks Opera, I can't purchase it right now since they won't sell to my country. I use VirtualDub, but once again I can't make an AVI file with it, I don't know why.
svdl ( ) posted Sun, 17 April 2005 at 8:43 AM
Seems like you've got corrupted codecs indeed. Try downloading and installing DivX 5.2.1, VirtualDub should be able to work with DivX. And if that does not work, I'm afraid the best course is backing up everything and a clean reinstall of your machine.
A_ ( ) posted Sun, 17 April 2005 at 9:46 AM
funny you should say that, svdl, my PC crashed about 3 times in the last 8 hours. :(
shedofjoy ( ) posted Sun, 17 April 2005 at 10:06 AM
sounds like your windows is going a bit funny, strangely mine was upto a little funnyness a week ago, so i formatted the hell out of my hard drive and intalled windows again, now im happy again... Try typing in AVI CODEC into google and see if there are any codecs you can download, as this may help. Don't bother with the MJPEG AVI codec, as i know Poser doesn't use that style of compression, i know this because my poser was making AVI movies before i downloaded the codec, (I needed this codec because my Digital camera uses it.. silly thing)
