Sat, Nov 23, 7:49 AM CST
Subject: P6 native unit now = 103.2 inches ... was not 100 inches in P5 ?
MarcioAB ( ) posted Sun, 17 April 2005 at 12:09 PM ยท edited Fri, 22 November 2024 at 8:10 AM
Full question on the title. Is that correct ? Not tested yet, but can this difference cause problems ? thanks.
AntoniaTiger ( ) posted Sun, 17 April 2005 at 1:21 PM
I have a Python script for P5, used to set the distance for the focus option in Firefly, which uses a value of 8.85 feet to one Poser Unit. This is 106.2 inches. Dr. Geep uses the simple-to-calculate 100 inch value. Some versions of Poser are believed to have used the simple 96 inch value. If the strange Imperial meadurements came to some nice round figure in metres, it'd make sense, but they don't.
geep ( ) posted Sun, 17 April 2005 at 1:47 PM
That's because Dr Geep is simple. (ha ha) ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Dizzi ( ) posted Sun, 17 April 2005 at 1:55 PM ยท edited Sun, 17 April 2005 at 1:58 PM
From the P6 readme:
"In previous Poser versions, Poser Native Units were sometimes handled inconsistently. In Poser 6, one Poser Native Unit always is the equivalent of 8.6 feet or 262.128 centimeters." And that should be 103.2 inches...
Message edited on: 04/17/2005 13:58
MarcioAB ( ) posted Sun, 17 April 2005 at 2:10 PM
Thanks. I missed the readme. So, from now on, we have consistecy on units ... good. Still need to see how old stuff will fit on this.
AntoniaTiger ( ) posted Sun, 17 April 2005 at 2:26 PM
People vary. Things don't. There is, for instance, a standard width for doorways in modern houses. So if you have a model scaled according to Geep, or Poser 5, or whatever, that's what sets the size of the scene. The only significance to the scale which Poser defines is if you're set to use feet or inches or metres, instead of Poser Units, on all the parameter dials. And I know Poser 5 had settings which used Poser Units even when everything else used feet.
LostinSpaceman ( ) posted Sun, 17 April 2005 at 3:17 PM
This explains why the Poser 4 Tiger loaded next to Poser 6 James came in about the size of a horse in comparison!
MarcioAB ( ) posted Sun, 17 April 2005 at 3:24 PM
Joint Editor for example, Antonia. I had a hope in P6 it would respect units, but not ... :(
geep ( ) posted Sun, 17 April 2005 at 4:00 PM ยท edited Sun, 17 April 2005 at 4:02 PM
Hmmm ... looks like I need to redo it ......... again. cheers, dr geep ;=]
Message edited on: 04/17/2005 16:02
cheers,
dr geep ... :o]
edited 10/5/2019
ChaosDrgn2 ( ) posted Sun, 17 April 2005 at 5:48 PM
Does that mean the 9' prop I have now is out of wack in P6?
geep ( ) posted Sun, 17 April 2005 at 5:55 PM
Hi ChaosDrgn2, That depends on which scale you want to use ... -and- To which 9' prop do you refer? cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
ChaosDrgn2 ( ) posted Sun, 17 April 2005 at 6:47 PM
yours of course. I have a copy of it, plus I've got P6 set for PNU so hopefully it wont' be off that much :)
geep ( ) posted Sun, 17 April 2005 at 7:08 PM
A PNU is a PNU is a PNU ! It is *EXACTLY* the same as a Wavefront OBJect unit. Here's a sneak preview of another tut I am working on ... because ... it's that time ... again ! cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
pakled ( ) posted Sun, 17 April 2005 at 8:44 PM
cool, I was going to ask how many chains that comes out to..;)
hauksdottir ( ) posted Sun, 17 April 2005 at 11:32 PM
Um, pakled, how many links DO you have? You need at least 2 links to make a coupling, and 3 links to make a chain, right? :running:
lesbentley ( ) posted Mon, 18 April 2005 at 1:42 AM
Any conversion between Poser and real world units is a matter of convention. The standard convention has been that one foot = 0.125 Poser units, one inch = 0.0104166... Poser units. On this same convention 1 meter = aprox 0.410 Poser units. On this convention a Poser unit is 96 inches, and 96 inches = 8 feet. Poser 5 introduced the option to display units in inches, and it seems that the convention they used in the first release was that one Poser unit = 103.23 inches. I have heard that diffrent releases/service pacs of P5 used diffrent conventions, one of them being 0.125 to the foot, but I haven't verifed this. The standard convention that one foot = 0.125 Poser units is based on work by Freakachu, here is the text of one of his readme files:
Here's the logic behind the prop. TwoMeter.pp2 and Ruler.pp2 are based on a bit of information from the Poser manual* which states that "Poser considers one DFX unit equal to the male figure's height--about six feet." In the Poser universe, the standard poser unit equals one and a third DFX units, or eight feet (which makes for a nice round number.) The poser unit is the distance that the translate tools or parameter dials need to move an object a single unit in Poser. (i.e. A "y-trans" setting of 1.000 would move an object 8 feet above an object with a "y-trans" setting of 0.000) Since the male figure is 0.750 poser units tall it's easy to do the math and divide the units into their English and Metric counterparts. Here's the breakdown: 1 foot = 0.125 poser units (a "box" prop scaled to 125% would be a cubic foot) 1 meter = 0.410 poser units (a "box" prop scaled to 41% would be 10 cubic centimeters) TwoMeter.pp2 and Ruler.pp2 are meant to approximate the heights of your Poser figures. For the TwoMeter.pp2 prop, each segment of the ruler, up to 150 cm, is approximately 50 cm in the Poser universe. Segments past 150 cm are 10 cm high. For the Ruler.pp2 prop, each segment of the ruler, up to five feet, would be approximately 12 inches in the Poser universe. Segments past five feet are 2.4 inches high. Now if someone could build a Poser scale. AMc *p 167 - - - - - -
There are other conventions such as Dr Geeps. Personally I stick with the one Poser unit = 96 inches = 8 feet, one foot = 0.125 Poser units convention.
hauksdottir ( ) posted Mon, 18 April 2005 at 3:46 AM
Since the basic Poser Unit is referencing a human male model, it doesn't have to be absolutely precise to the millimeter. Having dated normal males in a height range of 5'2" to 6'4", it seems obvious that they could all walk through doorways and sit down in a mass-produced chair without too much fretting and worrying about whether their feet would touch the floor. Is Vicky taller than Posette? Does it matter? If a figure converts to 5'6" or to 5'7 1/2" does that make the intended character any more intelligent, feisty, sexy, powerful? What does any number have to do with body language? Carolly
MarcioAB ( ) posted Mon, 18 April 2005 at 4:45 AM
1. Set Display Units (General Preferences) = Poser Native units. 2. Using the zTran Dial, move anything on Z by 1 poser native unit. 3. Set Display Units = Inches 4. Look at the zTran Dial again ...
Poser translates 1 Native unit to 103.2 inches.
Do the same thing on Poser5 and the result will be 100 inches.
geep ( ) posted Mon, 18 April 2005 at 7:33 AM
Hi MarcioAB,
I tried your little experiment with Poser5 (v5.04.325) and the result was 96 inches translated from 1 "Native unit."
Wuzup with that. huh?
BTW -
What version of Poser5 do you have?
PC or Mac?
Coffee, tea, or milk?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 18 April 2005 at 8:05 AM
re:*"Now if someone could build a Poser scale."* Someone did. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
hauksdottir ( ) posted Mon, 18 April 2005 at 8:17 AM
How do we know that he isn't wearing elevator shoes? ...and why is the measurement based on a MAN's height anyway? If 95% of the renders are of naked women, why not use a woman's height as the standard? Carolly
geep ( ) posted Mon, 18 April 2005 at 8:28 AM
Or, maybe a woman's ...
(nevermind) ;=[
cheers,
dr geep ... :o]
edited 10/5/2019
MarcioAB ( ) posted Mon, 18 April 2005 at 9:12 AM
Carolly must be a very funny person. She has a point (does 5% matters?), but being pessimist, I think this changes in units may end up in troubles somewhere. In CAD systems, changes in units or tolerances are terrible.
Dr. Geep ... you caught me. I got a new PC and regard Poser, I installed only Poser6 on it, so, I do not have Poser5 installed anymore to test. I got that information (the 100 inches) from my previous notes - but I believe you ... so, title change.
MarcioAB ( ) posted Mon, 18 April 2005 at 9:24 AM ยท edited Mon, 18 April 2005 at 9:26 AM
Carolly, with the "new" Poser6 native unit (8.6 feet tall), that would be a huge native naked woman ;)
Message edited on: 04/18/2005 09:26
MaryK ( ) posted Mon, 18 April 2005 at 8:56 PM
Well if you go back to the orignal Star Trek the Orion Slave women were supposed to be 8' tall. Maybe they used one as a scale model? (ducks)
geep ( ) posted Mon, 18 April 2005 at 9:04 PM
... quack, quack!
cheers,
dr geep ... :o]
edited 10/5/2019
hauksdottir ( ) posted Tue, 19 April 2005 at 3:23 AM
Ducks don't have scales, they have feathers... except the ducks from Orion have metallic plates and the clattering is quite fearsome. The sky darkens and fills with the noise of armies and the guardians of the granaries shudder at their approach. Hmm... 8'6". That is a bit of a stretch, even for the supermodels on stilettos. However, I think a woman's height would have made more sense if Larry had thought ahead to how the program would actually be used. Since the height does keep changing, I'll suggest it to him. :) Considering that folks use CAD, MAX, C4D, Maya, Blender, ZBrush, etc... and not all those programs agree upon a standard height, it really is not essential that Poser conform to any one of them. As long as the native units are always native units and roughly set to human standards, we should be fine. Consider this: the neolithic "yard" was a bit over 29", that didn't stop our primitive forebears from setting up trilithons. If Stonehenge, the Haggia Sopphia, the Parthenon, and the dome of St Paul's manage to stay up despite all having been built to a different standard, then why are we arguing over a virtual sliver? Carolly PS: I know that Orion is a constellation, not a planet.
