Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 27 6:56 pm)
those space suits are cool too The space suit, the padd (third pict) and all clothing used here is from Poserworld. (shameless plug) The best Poser related investment I ever made :) tools and tool box from vanishingpoint.biz
My Homepage - Free stuff and Galleries
I think it will work if you split the vertices and weld back what needs to be round.
I brought into p5 at one point and it gave an error message about it not being the right version but it brought it in anyway and all the materials appeared ok (didnt look to close though).
I have changed the materials a bit since that test so i dont know if that will cause problems.
the zip file is only 336KB, give it a try.
Message edited on: 05/04/2005 09:56
Huolong, If you dont splitting Verticies you will have rounded corners in places I didnt intend to be rounded. If your ok with that then i guess that is fine. If you want to split the vertices it is a pretty straight forward process. I just wish i had the time to do it. How to: open the obj in UVMapper (the free one) edit>Tools>Split Verticies (it splits all verticies) File>Save Model... (overwrite your old one) insert it into poser (via the cr2) select the airlock. go to Grouping tool. everything will go dark and the current group will be in red. dont click on the model at this point. the grouping editor will appear. At the top of the grouping editor will be a pulldown with all the group names with arrows on either side. Use the arrows or pull down to change between groups. when you find a group that needs to look round hit the "Weld Group" button on the bottom right. Once your done just goto another tool and save your new figure to your library.
did you see this? http://www.renderosity.com/messages.ez?Form.ShowMessage=2160062
