If they're objects, open up 'Objects' from within Bryce(at the top of the work window, the little triangle next to objects) at the bottom of that dialog box on the left it'll have either 'installed' or' user' (also click the triangle next to either to bring up all the folders), select 'user', at the bottom on the right you'll see 'import', 'export','delete', select import, browse to where you're keeping your obps, select one and click the checkmark. Repeat for each obp you wish to import... When collecting obps from freestuff etc., and also when exporting your own, keep themm in a folder in 'My Documents' and not in the Program files under 'Bryce', less chance of losing them to weird bugs and things.....
Bryce Forum Coordinator....
The rock stack ain't working properly for some reason. I've sent AS an untextured version to try. If that doesn't work I'll do a tutorial on how it was built.
http://joevinton.blogspot.com/
I am having problems with the obp files I have downloaded..all of them. I have no problem importing obj,3ds,lwo and so on... Do you know what the problem could be?? And yes,I am a newbie when it comes to Bryces
