Sat, Nov 30, 3:10 AM CST
Subject: Importing .3DS files
magnus13 ( ) posted Sun, 29 May 2005 at 7:43 PM · edited Tue, 26 November 2024 at 6:32 PM
Hi, Is there a particular way to import a .3ds object into Poser 5? I imported a model which is fine in max, but ended up in 3 pieces when I imported it into Poser (head separated, feet back to front etc.). What am I doing wrong? Thanks. Michelle
wheatpenny ( ) posted Sun, 29 May 2005 at 8:02 PM
Site Admin
For some reason, some 3ds files import with no problems at all, others import with one or more problems and there are others that refuse to import at all. One thing that might help is to import it into a modeling program, or deep exploration (or even Bryce) and resave it in another format, such as .obj.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
lmckenzie ( ) posted Sun, 29 May 2005 at 11:41 PM
Attached Link: http://user.txcyber.com/~sgalls/
Try to use .obj whenever possible--it's the format Poser's most conmfortable with. If you need a converter, try the fre utility PoseRay. It's designed to export Poser scenes to POVRay for rendering but it can convert .3ds to .obj also and the .3ds support seems to be good, certainly better than Poser's.
magnus13 ( ) posted Tue, 31 May 2005 at 12:46 AM
Thanks for the help guys. :)
