Thu, Feb 27, 2:39 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 1:25 am)
Subject: Problem with my Dress
nio103 ( ) posted Wed, 29 June 2005 at 8:42 AM · edited Thu, 27 February 2025 at 2:31 AM
Attached Link: http://www.renderosity.com/photos/MSG2/Message2319041.jpg
I made this dress for poser and after boning it and comforming I got this problem with the back polygons, see picture, how can I fix that?
EnglishBob ( ) posted Wed, 29 June 2005 at 10:30 AM
It looks like a welding problem - I assume the gaps correspond with the borders between groups? This could be because the relevant weld statements are missing from the CR2, or because the vertices in the OBJ are not sufficiently close to be welded. They have to be identical - if your mesh has been affected by rounding errors during scaling, this can happen. Can we have some more details on how you made the dress? In particular, how did you do the grouping?
nio103 ( ) posted Wed, 29 June 2005 at 12:13 PM · edited Wed, 29 June 2005 at 12:16 PM
1.I made the dress in lightwave
2.Then I sent to posers SET UP Room.
3.There I Loaded up bones of another dress on top of this one.
4.Then I use the auto group editor to auto group
Message edited on: 06/29/2005 12:16
PhilC ( ) posted Wed, 29 June 2005 at 1:41 PM
With everything set at zero select each body part group in turn and click the weld button in the Grouping Tool window.
nio103 ( ) posted Thu, 30 June 2005 at 5:55 PM
That did not fix it can I send you the dress so you could check it out, and see whats the problems?
nio103 ( ) posted Thu, 30 June 2005 at 5:56 PM
could it bee couse, I used a dress as the bones from another model and them auto group those bones to my dress?
EnglishBob ( ) posted Fri, 01 July 2005 at 3:11 AM
I regularly borrow the rigging from another model, and I also use Auto Group Editor; the only thing different is that I don't use the Setup Room. I'll IM you an e-mail address, it may be quicker if I have a look at it. I'm not making any promises, though. :)
nio103 ( ) posted Fri, 01 July 2005 at 1:09 PM
Thanks englishbob
