Fri, Nov 29, 1:52 PM CST
Subject: Poser 5 in linux?
mjholt ( ) posted Tue, 26 July 2005 at 9:43 PM · edited Fri, 29 November 2024 at 1:52 PM
Hello, I am a graphic artist. I was wondering how you got poser 5 to work in linux? I installed codeweaver, then ran the poser 5 install through it, then ran the update (newest one) through it as well. I got to the serial number entry and zapped that through. Every time I try to load it, to starts up like normally, but then bails out on me, before it finishes loading. Could you give me a hint, on how to go about fixing this problem? Any info would be most appreciated. my specs below: Abit motherboard socket 754 for 64-bit Athlon 64-bit(3400) ati radeon 9600 pro (256mb) graphics card AGP 4x-8x this may be the problem--I can't seem to find an rpm for linux.(self-installer would be better) 1gb of ddr ram 400mhz Thank you for your help
markk ( ) posted Tue, 26 July 2005 at 10:07 PM
If there was an easy way to run Poser5 in Linux. I would go over to it. I recently helped an old friend of mine upgrade his computer to the AMD64 and boy does linux load and work faster than his old machine. I could suggest wine, but I never got it to run at all well in Linux.
randym77 ( ) posted Tue, 26 July 2005 at 10:10 PM
People have tried, but so far as I know, no one has fully succeeded in getting Poser to run on Linux.
markk ( ) posted Tue, 26 July 2005 at 10:22 PM
Your probably right randym77. The only only alternative that I can think of is Win4lin. It is not free, prices vary for windows operating system. Linux has a lot of things going for it. But I am not going to abandon Windows, if Poser etc will not run or is not supported in Linux.
mylemonblue ( ) posted Tue, 26 July 2005 at 10:46 PM · edited Tue, 26 July 2005 at 10:52 PM
I've tried Poser 4 in linux years ago. With wine it actualy would open but never fully functioned or rendered. Since 3D in linux is a openGl type of operation I'd think the chances of getting results might come best from using Poser6 or DAZ Studio. Those two both use OpenGl. I wish I had extra hardware to try it on again. If people keep trying eventualy it will be done. As for the radeon I'm sure that situation isn't helping. I've used NVidia based cards in the past just because they did real well with OpenGl support. Good luck.:)
Message edited on: 07/26/2005 22:52
My brain is just a toy box filled with weird things
mjholt ( ) posted Tue, 26 July 2005 at 11:30 PM
Supposedly, a few have managed to make it work in linux. My problem is, I love the efficiency of linux SuSe 9.2, but I need to run only poser 5 and photoshop on it. With my new 64 bit, XP and XP64 really crap out on me. I'm sure there will be a solution someday, soon hopefully... Thanks for the input.
tastiger ( ) posted Wed, 27 July 2005 at 3:03 AM
I have run Pro Pack in Knoppix - but alas have had no success with P5 or 6......
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz   3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
dona_ferentes ( ) posted Wed, 27 July 2005 at 6:17 AM
This topic comes up on a fairly regular basis. Some people have got Poser working in Linux, but only very inefficiently. If it was possible, a lot of us would make the move. Poser is the only piece of software that keeps me tied to Microsoft.
mamba-negra ( ) posted Wed, 27 July 2005 at 8:18 AM
Win4Lin works, but it's so slow, it's not worth the time- unless you just work with Poser Pros without anything added to your runtime. I think the slowdown there is purely the library code being slow + an emulated filesystem. Also, when I was using win4lin, there was a very serious restriction on the memory. The newest version might be better, though. eric
