Wed, Feb 26, 11:11 PM CST
Forum Moderators: RedPhantom
Subject: Cr2 editor
nio103 ( ) posted Wed, 03 August 2005 at 7:59 PM ยท edited Wed, 26 February 2025 at 8:10 PM
cant figure out the cr2 editor, all I want to do is delete the extra surfaces I got from the borrowed bones and another file. Also how how do I delete the extra morphs I got from borrowing the bones. Cant tell what stuff means in this editor
Jim Burton ( ) posted Wed, 03 August 2005 at 8:07 PM
O.K., what you see in CR2 Editor is basicly the CR2 in outline form. You can open each group up by clicking the little plus on the left, and then the groups inside that by doing the same thing again, you can open it up all the way to see each line of the morph deltas, if you like. You can click on any line and delete it (which also deletes everythin inside it), just hit the Delete key on the keyboard. You can also right button click on it to get that and other useful options. The top part of the CR2 is the parts listings, in the middle comes the meat of the CR2, the body parts with the channels inside them (morphs are just one of the channels, others rotate and scale and stuff.) Down near the bottom (inside "Figure"_ are the parent/child lists, the welding list followed by the materials. It is all in plain text, not that hard to figure out what does what, I think. Bear in mind I've been doing this a long, long time, though. ;-)
DCArt ( ) posted Wed, 03 August 2005 at 8:43 PM
Here's a screen shot, if that helps ... the materials are listed in the figure submenu near the bottom of the CR2. Expand it, and you'll see all of the materials in your object (some are highlighted in the figure).
Jim Burton ( ) posted Thu, 04 August 2005 at 11:55 AM
I should have added you can actually delete all the materials, if you wish. Poser will recreate them and put them back in when you resave it.
