Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
If you have a straight up script it will not create a *.pyc file. If you have a set of modules, such as class defs, in a separate file(s) that you import it will then generate the *.pyc file. If you want to generate a *pyc file then break out most of the script functionality into a separate file and then use the import. As an example from one of my scripts: from Tkinter import * import Pmw import poser from ActorTest2 import * The ActorTest2 file which has my code in it will be compiled down to a *.pyc file. I haven't seen any real speed difference between the *.pyc and *.py files. There isn't supposed to be too much anyway. I see a bigger lag waiting for it to spin up Tkinter.
Has anyone figured out how to get PoserPython to create a .pyc file? The File > Run Python Script option gives .pyc files as an option but I been chasing my tail on how to create one. Yes, I do know what they are. ;-) All of the other versions of Python I've tried normally create them when the script is successfully run but not PPython.
