Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
"OMG What the...." I hear you scream! worry not, as you can see, this is not exactly a simple material, but its not as complicated as it first appears. many of the nodes are duplicated 3 times, each with different colors for there respective areas.
a quick explanation :
Simple Color controls the scale or size of the peices of "rock" and the gaps between them that the lava is in.
Simple Color 2 controls the ratio of "rock" to lava. changing the this node to a lighter shade of gray will make the lava become more yellow and defined, darkening it will start to close up the gaps.
over the next few images, these 2 nodes plus the fbm nodes are included as each area uses them
Message edited on: 08/22/2005 03:42
TemplarGFX
3D Hobbyist since 1996
I use poser native units
notice these nodes are plugged into both diffuse and ambiant color, this is to give the "rock" its color, and the lava its brightness.
TemplarGFX
TemplarGFX
these nodes, excecpt for the black and white coloring, are practically identical to the diffuse nodes above.
now, rather than trying to explain all of this in detail, please try and copy what you see into the material, and see as you build the material up, what each does, and how it effects the overall texture. if you have any questions, feel free to throw them up here! for the most part, you can ignore simple color and simple color 2, these are not actually needed, but when it comes time to change the size and general look of the material, they save you about 15 number changes! Simple Color goes into scale and spot size only simple color 2 goes into threshhold on the spot nodes
Message edited on: 08/22/2005 03:50
TemplarGFX
templargfx. I've been experimenting more and more with Poser materials and you can for sure get some awesome results. Thank you so much for sharing this with all of us. It's very insightfull and helpfull to me!
Food for thought.....
one of the great things with the spot node and any other threshhold based 2 color node like (Clouds, Spots, Granite, Marble, Wood) is that you can layer these in an ever increasing detail, using the threshold to make each layer larger or smaller than the previous such as in this material
TemplarGFX
Thank you very much for sharing this.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
TemplarGFX
167 Car Materials for Poser
