Hi! Los Azahares uses .bum files for bump maps Poser Artist/4. PP, Poser 5 and 6 use jpgs for bumps. You have two versions of Los Azahares in the Los Azahares Props Folder. One is for P4/Poser Artist, and the other, named: Los Azahares_P6 is for Poser Pro Pack, 5 and 6. If you are using Poser 4/Artist, you can convert the jpg's to bumps before you load the prop files. As the readme indicates, the textures are in: Runtime:textures:Moyra:Los_Azahares and all the bump maps end in _B (underscore B). If you are using a later version of Poser, you can just load the appropriate file, no need to convert anything. Hope this helps, Moyra
Y'know, I hate to complain about inexpensive props...but I bought Los Azahares from DAZ and I have yet to be able to get it to work on my computer. I've got an Athalon based system, 512MB of RAM, P5, and every time I try to use the prop it takes up to two hours searching for bmp maps and finally locks up the computer. I tried posting to the DAZ Nuts n Bolts forum but for some reason nothing is showing up there... Any suggestions?
