Fri, Nov 29, 5:00 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 1:45 am)
Subject: p4 nude male and PPP - anyone solved missing hip?
Mason ( ) posted Mon, 26 February 2001 at 10:01 PM ยท edited Mon, 25 November 2024 at 2:49 PM
I've been trying to find a solution to the missing p4 male hip in PPP. I've tried Genitals on and off with no luck. Has anyone found a solution?
weirdass ( ) posted Mon, 26 February 2001 at 10:05 PM
Attached Link: http://www.weirdass.net
Quoted from a Curious Labs technical support email on this subject: The missing genital switch needs the hipnogen object in a runtime/geometries folder that was missed. Runtme/Geometries/Poser4Figures/create a folder named "P4NudeMphMan" and copy the file from P4NudeMan called "blHipNoGen.obj" to the new folder. Try the above I cannot open the CR2 to be sure it is the proper path the above solution is for windows but the folder arrangement is most likely Identicle. Tech PS The Poser 2 figures work with the genitals on or off. Make sure you did a clean (OS base extention set) install and also allow Propack to update the Metacreations version of Poser 4 do not patch. Also remove the old folder (BACK UP CUSTOM STUFF) before installing Poser and PPP(propack)
nitreug ( ) posted Mon, 26 February 2001 at 10:45 PM
You said weirdass "do not patch". I thought that someone else said that the 4.03 patch has to be apply before to add PPP. I am a little confuse. DO you mean install a fresh Poser 4 and add PPP directly?
weirdass ( ) posted Mon, 26 February 2001 at 11:45 PM
Don't ask me, this is verbatim from the email that curious labs tech sent me. I'm just passing it on. Mitch
JeffH ( ) posted Tue, 27 February 2001 at 12:55 AM
The PP includes the 4.03 patch. Funny thing is, I don't have that hip bug under win95; everything works as it should. -JH.
Mason ( ) posted Tue, 27 February 2001 at 11:48 AM
I looked at the cr2 and noticed the section for the ip geometry desc is actually missing info. Kind of scary to be sure.
JeffH ( ) posted Tue, 27 February 2001 at 12:13 PM
Is this for a figure saved to the library? All the default ones work okay for me.
weirdass ( ) posted Tue, 27 February 2001 at 3:37 PM
Imagine if your doing a daily comic strip and half of your cast lost their hips... now thaat is scarrrry
