Sat, Nov 23, 12:46 PM CST
Subject: Please help!!
KaitNightshade ( ) posted Sat, 03 March 2001 at 1:22 AM · edited Fri, 09 August 2024 at 11:48 PM
I have been using Bryce 4 for quite some time now and im reallygood with it, but i have noticed there are keyboard commands to make my work easier. if these are in the manual, i wouldnt know, i dont have it. so if anyone has a complete list of keyboard commands or knows where i could find them, please help.
joke ( ) posted Sat, 03 March 2001 at 10:48 AM
I have found these by asking others, reading manuals and just plain testing keyboard combinations: Ctrl-Alt-R full render Ctrl-Alt-T Edit mesh Ctrl-Shift-N animation setup Ctrl-3 sky mode Ctrl-T animation (AML) Alt-M deep texture editor F5 hold this down and and move objects. The nano preview displays continuously Ctrl-M material lab Ctrl-Alt-E object attributes Ctrl-Alt-M same as pressing "Leonardo" icon Ctrl-A select all Ctrl-1 create palette Ctrl-2 edit palette Ctrl-K sky lab Ctrl-O save changes Ctrl-Alt-N document set up Spacebar hold this down and you can move the palettes (using mouse+mouse button) and windows that are usually attached to the sides of bryce windows There are also menu menu option that work a little bit differently when you press the mouse button on them longer. If you have selected an object (using Tab for example) "I" makes it an intersect object, P a positive, N negative etc.
mythris ( ) posted Sat, 03 March 2001 at 11:56 AM
also, if you press "s" then it will bring up the select menu on the bottom of Bryce, which lets you select by object type
KaitNightshade ( ) posted Sun, 04 March 2001 at 2:09 PM
great, but i know there are more functions such as the arrow keys move the object on the x and z planes and certain letters corespond with settings like [N] sets the object to Negative, [I] sets it to Intersect and [P] sets it to Positive. the number pad also has several functions. you can select different camera views starting with 0 as the director view and go in order with 1,2,3, ect. but some times i'll press a key, it does somthing but i dont know what. I need a full list of keyboard functions.
