Sat, Nov 23, 5:34 AM CST
Subject: problems
ptrik ( ) posted Wed, 19 October 2005 at 10:44 AM ยท edited Sat, 23 November 2024 at 5:20 AM
Hello, I use Poser6 with Mac bone 10.4 and I do not arrive has to export with the format obj. Indeed a small caster appears it turns without end. I am obliged to force the software has to leave? Y has to you it an answer has this ?. Bonjour , J'utilise Poser6 avec Mac os 10.4 et je n'arrive pas a exporter au format obj. En effet une petite roulette apparait elle tourne sans fin. Je suis obligde forcer le logiciel a quitter ? Y a t'il une ronse a ce proble Merci
leather-guy ( ) posted Wed, 19 October 2005 at 12:33 PM
Revised headline may attract effective help.
JOE LE GECKO ( ) posted Wed, 19 October 2005 at 6:28 PM
Love the way Babelfish ( or similar engine ) translated Mac OS ( "os" meaning "bone" in french ) :) J'ai Poser6, mais malheureusement, je travaille sous XP, je ne peux pas t'aider l..
DominiqueB ( ) posted Thu, 20 October 2005 at 3:39 PM
Attached Link: http://www.poserpros.com
Tu devrais aller poser ta question au forum franis de Poserpros ( le petit coin d'akin ). Je ne travaille pas sous MAC. Qu'est-ce que tu essaies d'exporter exactement?
Dominique Digital Cats Media
ptrik ( ) posted Thu, 20 October 2005 at 4:51 PM
Un personnage poser exporter dans nimporte quels types de format 3d ou image 2d ?
Curious_Labs ( ) posted Tue, 01 November 2005 at 2:37 PM
This problem may be due to the DivX 5.2.1 codec. This video codec is not fuly Tiger-compatible. We have found that if this codec is installed, the problem that has been described will occur. Removing the DivX 5.component file from the Library:QuickTime folder should cause Poser to work properly. Regards, e frontier Technical Support
ptrik ( ) posted Tue, 01 November 2005 at 5:10 PM
Miracle marche! Merci beaucoup.
