Fri, Nov 29, 4:01 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Replacing P3 Head to Vicki Head
Drai ( ) posted Tue, 06 March 2001 at 7:01 PM · edited Mon, 25 November 2024 at 3:58 PM
I have a REALLY good P3 female face that I created a while ago and would love to transfer the head to a Vicki body. I replaced it as a prop, but the head acts totally independent from the body and I've lost ALL the morph targets. Can anyone help me fix this, or am I screwed? The head will probably be near impossible to remodel from a Vicki model.
ScottA ( ) posted Tue, 06 March 2001 at 10:46 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=440&Form.ShowMessage=244191
This explains how to make the new figure. The biggest problem you'll have is that you'll have a seam where the P4 head meets Vickie's neck. You can weld them together then re-split them in a 3Dmodeling program to get rid of the seam. But this will result in you losing the morphs for the P4 head. Because the vertices will be different than the original one. ScottA
Drai ( ) posted Wed, 07 March 2001 at 5:40 AM
Thanks, I'll try that out and let you know!
