Wed, Feb 26, 8:19 PM CST
Forum Moderators: RedPhantom
Subject: Standing in the shadows...
mdbruffy ( ) posted Sat, 19 November 2005 at 7:58 PM · edited Thu, 13 February 2025 at 3:29 AM
I need a way to take the shadow of a supposedly semi-transparent outfit and make it look as if some light is passing through it. The shadow of the person wearing the outfit would still be totally black, but the outfit's shadow would be greyer. I hope that's clear.I've attached a test render to show what I mean. The gown was originally the morphing fantasy gown from Daz. follow the white arrow and hopefully you'll see what I mean. The gown's shadow should not be as dark as the figure's. help, please.
rabbit_dawn3d ( ) posted Sat, 19 November 2005 at 8:47 PM
Poser propack, 4, 5, or 6?
mdbruffy ( ) posted Sat, 19 November 2005 at 8:51 PM
Poser 6. no propack.
sturkwurk ( ) posted Sat, 19 November 2005 at 10:07 PM
Is Raytracing on? Firefly render? High quality? Shadow Size?
I came, I rendered, I'm still broke.
mdbruffy ( ) posted Sat, 19 November 2005 at 10:28 PM
Ray tracing is on. It is firefly render and the compression quality is max.
mdbruffy ( ) posted Sat, 19 November 2005 at 10:30 PM
another note. These are settings I always start out with. normally they're more than enough.
svdl ( ) posted Sat, 19 November 2005 at 10:32 PM
You can either use raytraced shadows or a large shadow map (at least as large as the largest dimension of your render).
My gallery   My freestuff
mdbruffy ( ) posted Sun, 20 November 2005 at 5:44 AM
I switched the main light to ray traced shadows and turned the shadows off on the other two. But it doesn't seem to work- the shadow looks broken.
face_off ( ) posted Sun, 20 November 2005 at 7:51 AM
I think your best bet would be.... 1) Render the girl and dress with a 0.5 strength shadow with your original settings (on the main light) 2) Remove her dress and do a shadow-only render and merge with the render from step 1) in photoshop.
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
mdbruffy ( ) posted Sun, 20 November 2005 at 2:17 PM
I rendered the dress with the 0.5 shadow and when it was done, I noticed something that might have a baring on things. Look at the bottom of the gown, where the trim is. At that point, the light only has one layer of gown and pattern to get through- and there is a difference in the shadow. BUT, looking behind her, past both sides of the gown and her, we get the totally black shadow. I'm thinking there's too much pattern in the gown to get the difference in the shadows like I'm trying for.
