Sat, Nov 23, 1:34 PM CST
Subject: Poser house windows - free from me.
billisfree ( ) posted Tue, 10 January 2006 at 9:24 AM · edited Sat, 23 November 2024 at 1:27 PM
Hi After a lot of work, I created some windows that seem too good not to share. Yep... so simple... only takes ONE square prop and three adjustments in the materials room. Is the anyway to post them and make them available to others?
Acadia ( ) posted Tue, 10 January 2006 at 12:16 PM
I don't think you can share the square if it's using one of Poser Primatives. You can take a screenshot of your material room and post the image here.
billisfree ( ) posted Tue, 10 January 2006 at 3:02 PM
Hey! you make it sounds like you can NEVER pose any pictures, props, etc with ANY program you bought. Are you telling me that because I used my poser program I can't give anything away?
Richard T ( ) posted Tue, 10 January 2006 at 3:05 PM
If you have a web hosting service you can make it, just zip up the mat, avialable as Renderosity freebie. I do have plenty of bandwidth to host it, as a Renderosity freebie, if need be. http://www.poseruniverse.net/ Richard
vilian ( ) posted Tue, 10 January 2006 at 3:05 PM
What Acadia meant is that you can't share stuff that was shipped with Poser, not rendered/rigged in Poser. You can share Material Room settings, but you can't give away one of Poser Primitive Props, or anything else.
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
Acadia ( ) posted Tue, 10 January 2006 at 3:19 PM
Thanks Vilian, that's indeed what I meant, which is why I suggested just posting a screenshot of his material room settings so that people can use their own primative and his settings.
Miss Nancy ( ) posted Tue, 10 January 2006 at 3:24 PM
I don't think one can copyright squares, balls, etc., but one might ask in the appropriate forum. in any case, a pp2 file will only refer to the primitives; it doesn't contain them.
Dave-So ( ) posted Tue, 10 January 2006 at 4:42 PM
cant copyright a "ball", but can copyright content found in the software program Poser
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
kobaltkween ( ) posted Tue, 10 January 2006 at 7:05 PM
if it's just a material setting, distribute that. just as you would if it were a latex or metal material. that way people can use it on anything they like.
artistheat ( ) posted Tue, 10 January 2006 at 8:32 PM
Just check with CL TOS....But I don't think there will be any problems sharing something you can make in any 3D program....Makeing props with primitive and sharing them shouldn't be a problem....It's done all the time just check the freebie area...
Singular3D ( ) posted Thu, 12 January 2006 at 6:27 AM
Online Now!
How should you make items with a modeler, if you can't share the models made from primitives of this program. I use all kind of primitives to make models in Cinema 4D. They end up in vertices and polygons. Why should Poser be different. Characters is a different issue.
