Fri, Nov 29, 1:19 PM CST
Subject: Pro Pack Bummer....
mobius ( ) posted Mon, 19 March 2001 at 11:51 PM · edited Tue, 26 November 2024 at 2:46 AM
I just installed my new pro pack. Went to do some joint editing (tried opening the joint editor) and bam! I get a bogus window that I can't see. I tried resetting all prefs to factory default to no avail. I'm a pretty dissatisfied customer right now! Anyone know what's going on? Thanks in advance
JKeller ( ) posted Tue, 20 March 2001 at 12:03 AM
I just installed pro pack today as well. I've done a little joint-editing but I have not run into this. When you installed Pro Pack did you install it over an unpatched version of Poser 4?
JeffH ( ) posted Tue, 20 March 2001 at 2:51 AM
What OS are you using? -JH.
ghelmer ( ) posted Tue, 20 March 2001 at 10:26 AM
I too am having some annoying problems with the Pro Pack!! When I try to apply a new texture or trans map it won't allow it. Wierd eh?
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
mobius ( ) posted Tue, 20 March 2001 at 11:13 AM
JKeller, Nope. right over an up to date version. I using windows 2000. It looks like it's going to be cool once I get it running! mobius
JKeller ( ) posted Tue, 20 March 2001 at 11:20 AM
You should reinstall Poser 4 direct from the CD and then install Poser Pro over it without installing any of the MC/CL patches.
I kept my patched version of P4 in my Metacreations directory and then installed a 2nd copy in a Curious Labs directory and the installed the ProPack over that. I will generally work in Poser Pro, but I'll always have 4.03 available for testing purposes.
DonnyD ( ) posted Tue, 20 March 2001 at 1:46 PM
Attached Link: http://www.donnyd.com
Having 2 versions installed at the same time in windows won't cause any problems with the registry? I mean, does it mess wiht your preferences? Extremely curious since I just ordered propack Donny
JKeller ( ) posted Tue, 20 March 2001 at 2:19 PM
Well, your poser preferences are installed within your poser directory, so as long as you keep your two versions in separate directories, they will each read their separate preferences. As far as file type concerns, I haven't tried double clicking a .pz3 file yet so I don't know if the pz3 will open in P4 or PP. I can always change this if I need to, but I rarely open a pz3 from windows anyway.
BTW, I can't run both P4 and PP at the same time. If PP is running and I try to launch P4, it merely makes my PP window active.
Daramski ( ) posted Tue, 20 March 2001 at 7:32 PM
I have'nt stopped having problems with the pro pack, and really wish I backed up my poser folder before I installed it. Sure the new add ons are pretty great but my poser is always crashing, I'm not to happy about it. I've now got two lots of poser installed one with the pro and one without.
ghelmer ( ) posted Wed, 21 March 2001 at 1:14 AM
I reinstalled Poser, the 4.03 update & Pro Pack! Still I can't change any textures!!!!! Aaargh, good grief! Rats! I feel like a blockhead! Does anyone have any ideas what's up? I'm running WinME with a Geforce2 & 160meg Ram! Idon't know if my hardware's causing any bugs to become prevalant or if it's just Poser or what! H E L P ! ! !
The GR00VY GH0ULIE!
JKeller ( ) posted Wed, 21 March 2001 at 1:21 AM
:: I reinstalled Poser, the 4.03 update & Pro Pack!:: Install Poser off the CD and then install Pro Pack. DO NOT install the 4.03 patch on the same instance of Poser you are upgrading with Pro Pack.
ghelmer ( ) posted Wed, 21 March 2001 at 10:43 AM
JKeller - That's what I did first & had the same problem... After checking in my manual & the Curious Labs Support area, it said that the ProPack wouldn't function with a non-updated version of Poser (but it did function - just not properly). Then I reinstalled EVERYTHING! And was left with the same problem... sigh... I'm going to give up until the weekend. Thanks!
The GR00VY GH0ULIE!
Daramski ( ) posted Wed, 21 March 2001 at 12:01 PM
I've tried absolutely loads of different things to get it working, The only thing I have'nt tried yet is using the disk for a frisby.... or a place mat for my coffee mugs.
mobius ( ) posted Wed, 21 March 2001 at 12:38 PM
My problem seems to have fixed itself by re-booting my computer...go figure!
ghelmer ( ) posted Wed, 21 March 2001 at 2:46 PM
Hey Mobius... sounds like the solution from the IT guys at my work to all computer problems here!!! HAHAHAHAHA!
The GR00VY GH0ULIE!
