One way to overcome this problem is to make two separate renders, transfer the finished images into Photoshop or another paint programme, have 2 layers (one for each render) and change the opacity of one (or the other) until you get something you like. just a thought. Not tried in Bryce as i havent come across the action to use. Sorry Marc.
Smile, your dead a long time :)
Attached Link: http://www.pinhead.robbes.com/tutorial/Mario/mg_CTATerrains.htm
Sorry, only now I see that you'll need Photoshop or PaintShop Pro to do it. It talks about DEMs, but you can do the same thing with your own terrain if you just export image of your terrain from Terrain Editor. Just remember that the resolution of the terrain will be the size of the image - resolution 512 will give you an image of 512 x 512 pixels.-- erlik
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2503987
Checkout the A+B+C blend in post #4,5 and #6 of the above short tut. Save both youre A and B textures in the Textures library and create your own Alpha texture for the C or "D" component.Message edited on: 01/21/2006 20:15
Cheers
GG.
WHO said Kiwi's can't Fly ?????
