I have. Yes. No. (sorry, lol) If you know how to apply materials in P5/6 (6 by default, since there are some functions that simply work better there) you can use them with no prob. THe package comes with a really great set of good instructions, as well. They are, quite simply, some of the best shaders ever created for 3D work -- and not jsut for poser. Getting some of these effects into higher end applications would really up the ability of artists to create some incredible effects. And the future packs he's still got to come are promising to be evenmore versatile.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1139014&Start=1&Artist=zulu9812&ByArtist=Yes
*Could you post what you have created with them?*Sure, check out the link - it's my latest gallery image, done with Cartoon Shaders.
Cartoon Shaders is the beez neez. I know that $45 is expensive, but you won't regret it. Plus, the author's a nice guy who'll help you out if you need some tips with the material room. Message edited on: 02/04/2006 21:54
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2540414
Did you see this thread? It has more examples.Attached Link: http://poser.rois-sorciers.com/ShaderWorks/index.htm
It's very easy to use. But it can take some time to apply the cartoon shader for each material when you have a big scene.I'm adding a feature to my little application (still in Beta) that would apply the cartoon shader depending on various parameters (diffuse color, ambiant color, alternate diffuse or even an average color from the texture map). It will apply a cartoon shader to all materials automatically.
Before adding this feature, i must look with you, Olivier, if i can make it available or not. Once it works for me, i will discrib how it works, so you can tell me if i can or cannot add this feature. Edited to add the link.
Message edited on: 02/05/2006 07:00
Food for thought.....
image in post 12 is impressive IMVHO, but one should try to match neck and head tex, increase the smoothing node/parameter and increase the line width node/parameter. In addition, I'm guessing the eyes are trouble spots (transparency fx for lashes, brows, cornea et al.) I realise y'all can't post screen shots of Olivier's materials set-up, but it's imperative that you have control over variables like that.
The Toon shaders have options for transparencies... but i'm right now working to add those material to my app. The picture is only using the "single colors" shader. I didn't use the "Highlight", the "reflective", the "raytrace", the "FX" and the "Texture" shaders. For now, everything is implemented, except the FX and textures shaders. I'm working to add the textures shaders, because the transparency toon shader are essential. Once i have done this, i'll post a screenshot of the same picture (post 12) with the transparency shaders.
Looks even better now!
I find it hard to believe you did set up all of toon materials in less then a minute. I've been doing a lot of scenes already, but I can't do it so fast.... Am I doing something wrong, is there a secret I don't know of? How can you apply 135 materials in less then a minute or even apply one tone shader to so a number of figures and clothes? I'd love to know how you go about doing this....
This is his software that does the job for him. :) Pretty cool, eh? Semidieu, you need to add some features: Outline width AO response, and AO on or off Backlight FX width Anti-Light FX width Type of shader Texture Trans Bump It should be editable for each figure or prop: one setting for each with an option to have the same play of parameters to be applied on the whole scene. If you can all of this, you have some gold in your hands! :D
I was already thinking to add these features... For instance, you can: - Select the material or actor where you want your toon shader. This mean you can apply different shader to different part. I will do some pictures tomorrow to show this... - All shader from the package are now useable; - It add the transparency when necessary; - it add the bump if available (and if you want). Now, i must make it more user friendly and add those little options Olivier said above. I will try to do this as fast as possible, but i broke my arm last thursday... so i'm writing/coding with one hand... But that mean also i can't go to work ;-)
Just to add this about the application: It's for Windows XP... and you must have the Framework 1.1 installed for it to work. It's actually in Beta and the version available DO NOT contain the "module" to automate the toon shaders... I hope to make it available very soon (perhaps until the end of this week...)What's Framework? Where do I get it?
PoserPro2014(Sr4), Win7 x64, display units set to inches.
www.danielroseartnew.weebly.com
Attached Link: http://www.microsoft.com/downloads/details.aspx?FamilyID=262D25E3-F589-4842-8157-034D1E7CF3A3
See attached link. You should also be able to get it via Windows update."Will this set work with Daz Studio?? If not is one for D/S a possibility in the future?? Thanks. :D " No it doesn't, since it is based completely on the P6 material engine and takes advantage of it's advanced features. D/S works complete differently with materials and misses these advanced features, but what else do you expect from a free application? Olivier would have to completely re-write all of the materials and that takes another year :-) You really need to upgrade to Poser 6 and get rid of the toy, if you want to play with the big boys ;-) @semidieu, sounds like a cool application. I didn't see that you created an application to apply the shaders this quickly. Unfortunally Framework 1.1 is involved, so I'll pass. I really dislike Framework 1.1 a lot, it always messes up my system, just like MS dot net. I could really use the application once you get permission to let it works with the shaders, but I'm not willing to install Framework 1.1 for it.
" don't have any problem with the framework 1.1... Did you install all the updates ? This could be an issue. I didn't thought it could be an issue, because i always had this installed on my machine without problems..." Most likely it doesn't cause any problems on your machine at all. I'm working with an application that allows me to create and code 3D interactive worlds and a few apps related to it. When using Framwork and a number of them at the same machine, I'm getting errors. I'm not dependant on Framework at all, but do need the others, so that's why framework is no go at my pc.
I installed Frameworks 1.1 and updated as much as I could find, but I can't get the ShaderWorks to work - I can't get the file unzipped and it says that the file may be corrupted etc. My partner suggested it might be because I'm using Windows XP Home - she has to use XP Pro for various aspects of her Web design. Any suggestions?
Aha! Got it. I'd redownloaded it twice already with the same negative results, but gave it another go anyway. Glad I did. Very cool, and thanks semidieu. Will play more later. Thanks Olivier.
Cool. I still haven't had much of a chance to play, but from what I can see this is going to be so useful. You guys really are very clever.
I finally updated my website with the ShaderWorks ART MATERIAL module. And yes, it's FREE ! You still need the ART MATERIAL by Olivier ;-) Please, read the instruction before running the application (you can download the instruction in the download page or simply download the "full" package). ShaderWorks will run on a computer with the Framework 1.1 installed. There is, currently, an issue with 64-bit machine. I hope it will solved very soon. Also, take a look at the download page and the status of the module. Every modules are working, but some of them aren't yet completed. If you're interested in testing these modules or have new/better idea, you can send me an email (look at my website). Finally, always do a backup before deleting/overwriting any files...This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Has any one used RDNA ART MATERIALS Vol.1 : Cartoon Shaders? Are they easy to use? Could you post what you have created with them?
