Fri, Nov 29, 2:42 AM CST
Subject: How's your render time...just for fun :)
fpfrdn3 ( ) posted Sat, 25 February 2006 at 1:10 AM · edited Fri, 29 November 2024 at 2:30 AM
Just thought it would be interesting to see what other people systems are doing with bryce for fun. Simple, go to the content folder in bryce 5.5 and bring up desmonema.br5(dont know if older versions have this file). Make SURE report render time is checked and just hit render button. My time was 8min 46sec. PCs and Macs I hope. Not to be comparing systems or bragging , just kind of a fun guage of systems since there are so many great artists here. You can put simple specs if ya want. AMD 64 3200+(754) 1gig-o-ram :-).
AgentSmith ( ) posted Sat, 25 February 2006 at 2:40 AM
08:28 AMD Athlon 3200+ 64-bit socket 939 1GB DDR400 Ram Gigabyte K8NS Ultra-939 nForce3 Ultra chipset Motherboard Windows 2000 Pro SP4 AS
fpfrdn3 ( ) posted Sat, 25 February 2006 at 4:06 AM
Hi AS. Yes my wow64 emulation did hurt me didnt it :). Also NF3, ECSboard, 400ddr (XPpro x64) non-OC.
Mahray ( ) posted Sat, 25 February 2006 at 6:39 AM
13:42 Intel Celeron 2.8 GHz, 1 GB Ram, Win XP Home.
Come visit us at RenderGods.
Ignore the shooty dog thing.
CrazyDawg ( ) posted Sat, 25 February 2006 at 7:11 AM · edited Sat, 25 February 2006 at 7:12 AM
00:31
AMD Athlon 3000+XP
3 GIG DDR 400 ram,Biostar M7NCD Ultra motherboard, Radeon 9600 SE video card..
Thats how long it took me to read this thread ;)
I don't have bryce so i can't do the test render for you..
Message edited on: 02/25/2006 07:12
I have opinions of my own -- strong opinions -- but I don't always agree with them.
TheBryster ( ) posted Sat, 25 February 2006 at 7:45 AM
Forum Moderator
15.93days. And I had to replace the cockroaches 4 times...;-)
AgentSmith ( ) posted Sat, 25 February 2006 at 6:29 PM
I don't know about your wow64 emulation hurting you. I am completely obssesive about having NOTHING start up with my PC that is not needed. That nothing is running in the background, ever. I also have keep my OS, my virtual memory, and my Bryce program on 3 seperate hard drives. (my girlfriend just shakes her head at me, lol) AS
fpfrdn3 ( ) posted Sat, 25 February 2006 at 10:05 PM
Yep, just installed new OS (x64), which I did a ton of research on, and knew what I was getting into. Soon as I fired up bryce with my custom bench *.br5 file (which always takes 25sec.) it took 30sec. It shows up as emulated (*32 or something). Now knowing a little more bout bryce, unless you are doing VERY heavy renders, it will only use 50 to 80 cpu time. Again, running an app in background(or that heavy render) will result in 94 to 99 cpu time, a good savings. This post was to see and give people here using this program some insight to rendering faster with or without buying new hardware. As I didnt see posts here about time and bryce rendering, I did forum search for desmonema.br5 which came with my 5.5 that most should have to compare. I also now only have 15 max process run in background. Lots who spent time and money on their rigs should be obsessive bout the system as you could only get more enjoyment out of a faster system(and should I say stable system too:).
CrazyDawg ( ) posted Sat, 25 February 2006 at 11:08 PM
wish i knew what things i could shut down from starting up or running in the background, was easy with win 98 but this win xp is confusing..
AgentSmith ( ) posted Sat, 25 February 2006 at 11:50 PM
*I use a small utility called Start Up Cop Pro to kill a lot of things that start up with the computer. The utility used to be offered for free from www.pcmagazine.com, I think they now charge to get access to those files. *Additionaly, I use the "Administrative Tools>Services" to disable any others programs that don't show up with Start Up Cop Pro. I've used these two operations on my Windows 2000, and my familys PC's, which are Win XP home. AS
Erlik ( ) posted Sun, 26 February 2006 at 1:03 AM
Attached Link: http://www.overclockersclub.com/guides/windows_xp_services.php
CD, here's the list of services, their status and what to do with them. If you don't have Services in Administrative tools, you can access them by going to Start -> Run -> and typing services.msc. If I'm not wrong, Spybot Search&Desstroy shows a list of services with their components. BTW, the first thing to shoot is Messenger service.
-- erlik
AgentSmith ( ) posted Sun, 26 February 2006 at 1:06 AM
If I'm not wrong, Spybot Search&Desstroy shows a list of services with their components. BTW, the first thing to shoot is Messenger service -------- yup and yup. ;o) AS
CrazyDawg ( ) posted Sun, 26 February 2006 at 1:17 AM
Thanks Erlik i'll look at that site. First thing i blew away was Messenger service..i was told by an IT not to use the windows messenger when i installed xp.
CrazyDawg ( ) posted Sun, 26 February 2006 at 3:14 AM
Ok i looked and read everything on that site. Now i'm totally confused on what i can and can not disable/stop..
Erlik ( ) posted Sun, 26 February 2006 at 6:54 AM
I had found a better list with definite settings, but I have no link, only a HTML file saved on my disk. And Windows Messenger is not Messenger service. While WM is vile enough and should be get rid of, it's the service that makes the spamming pop-ups possible. Then, things you dewfinitely don't need and can set them to Disabled: Alerter Clipbook Messenger NetMeeting Remote Desktop Sharing Network DDE Network DDE DSDM Remote Registry Routing and Remote Access Server Telnet and possibly Terminal Services, as well as Fast User Switching. That's just for security. You can try setting some other services to Manual, if in doubt.
-- erlik
marcfx ( ) posted Sun, 26 February 2006 at 9:20 AM
Best thing to do is hit the Windows key,(Between the 'ctrl' and 'Alt', then 'u', then 'Enter'......all your problems will cease :)
Smile, your dead a long time :)
EYECON ( ) posted Mon, 27 February 2006 at 10:04 AM
..... Unfortunately I don't use Bryce anymore... But I do try to testrender a few "freebies" that I may submit here in my fave forum... the bryce world.... Just for kicks heres my new system... been using it for half a year now. Intel perl motherboard Intel Pentuim 3.0 ghz hyperthread 1 gig ddr ram Nvidia quadrofx vid card 80 gig ram when i do run bryce... it run somoothly and faster thanmy past celeron 800mhz comp that died 2 years back... mmmm i may post a few maya renders in the future... for now you may check this art if you have time.... http://www.renderosity.com/viewed.ez?galleryid=1166612&Start=1&Sectionid=4&filter_genre_id=0&WhatsNew=Yes more power guys! eyecon
AgentSmith ( ) posted Mon, 27 February 2006 at 3:25 PM
"Unfortunately I don't use Bryce anymore" ------- I noticed you dropped out quite a while ago! ;o( My fave of yours has always been "Observe". AgentSmith
coldrake ( ) posted Mon, 27 February 2006 at 7:43 PM
07:29 Intel Pentium 3.0 hyperthread 2 gig DDR ram Dual 128mb Nvidia GeFORCE 6600 GTOC video cards Win XP Media Center Edition
EYECON ( ) posted Wed, 01 March 2006 at 6:18 AM
Thanks AgentSmith...You have been and still is my favorite forum overloard!... Like i said dropped out but not yet gone... as long as you and the guys are here... i'll persistenly keeep on coming back... =)
AgentSmith ( ) posted Wed, 01 March 2006 at 3:14 PM
Cool. :o) AS
