Sat, Nov 23, 4:57 PM CST
Subject: key frames...the "fill"
spinners ( ) posted Mon, 20 March 2006 at 9:41 AM · edited Sat, 23 November 2024 at 2:44 PM
I've got a key frame and pose at 30....got another key frame at 90...when i originally let poser fill it in (when i made my new pose) the guy did some pretty absurd twists and turns...I've seen erased them, so i've got 60 empty frames.... so how do i fill in the missing 60 frames?
Tunesy ( ) posted Mon, 20 March 2006 at 9:51 AM · edited Mon, 20 March 2006 at 9:59 AM
"so how do i fill in the missing 60 frames?"
Depends. You might need one more key or ten more. You'll usually need a key any place where an 'extreme' in the motion is happening. For example, if the figures hand is supposed to be raised completely over his head at exactly frame 48 then you probably need a key at frame 48. If you're simply trying to smooth out the motion going from your pose at frame 30 to your pose at frame 90 then you might want to go to frame 60 and adjust the pose that Poser has generated to eliminate wierd twists and limbs going through limbs. Maybe you'll have to repeat in other frames. You may or may not need to use different interpoation as well for one or more parameters. It really depends what you're doing.
Message edited on: 03/20/2006 09:59
