Sun, Dec 1, 4:23 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: High Res materials?
Vorta03 ( ) posted Fri, 31 March 2006 at 2:00 PM ยท edited Sun, 01 December 2024 at 4:07 AM
Hi, Does anyone know were I might find some high resolution materials for vue. any time I try to do a close-in shot, the terrain buckles and distorts. (does the same thing in bryce). Basically I am trying to build some terrain objects to use for a Daz Studio scene I am doing, ( a cliff, of which my characters are posed on, over looking a city scape-am using dystopia).-when I converted the the vue to wavefront obj. format, I had the image maps sized at 4018 by 4018- and included the bump map. (normaly a 4k sized image map looks great in daz, but the ones vue is creating don't) if you need me to I can post the objects-(if that is ok) David
bruno021 ( ) posted Fri, 31 March 2006 at 3:01 PM
The thing is when you export your terrain in a3d file format, Vue will create an image to map your terrain. This image represents the procedural material you chose to texture your terrain. It doesn't always work right. Also, what is the size of your Vue terrain? The standard resolution is 256x256, which is very low. You need 1024 to get a better result.
Vorta03 ( ) posted Fri, 31 March 2006 at 4:49 PM
That makes sense--I did not adjust the resolution in VUE I will try that... Thanks David
Elminster_ZK ( ) posted Fri, 31 March 2006 at 6:52 PM
wait - how do you convert .vob to .obj? This is possible!?! excited gasp
"Walk down the right back alley in Sin City, and you can find anything."
bruno021 ( ) posted Sat, 01 April 2006 at 3:27 AM
No, Zack, you can't do that in Esprit, only Infinite, and only with objects that are not locked from export by their creator. But Vue terrains ( not procedurals) can be exported, and with any Vue version (although I don't think Easel can export anything). This option is in the terrain editor window.
Elminster_ZK ( ) posted Sat, 01 April 2006 at 8:01 AM
oh, you mean terrains. Okay, thanks.
Vorta03 ( ) posted Sat, 01 April 2006 at 10:08 AM
I tried uping the resolution of the terrain actualy went as high ip as 4018x4018, and its still distorting at close in shots.... David
bruno021 ( ) posted Sat, 01 April 2006 at 10:34 AM
So I guess it's the texture, could you re try exporting without textures?
