Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Also, if you look at it, the left opening has a "return," i.e., there are polys on the inside of the hole. The right opening is two holes lined up on each other. If you were to loft that space closed than the right opening would also take on that distorted look. The distortion is because Carrara is applying a certain amount of smoothing to the hard corner. Creasing is one way to solve this. Two others are detaching faces, and adding a bevel at the edge.
