Sun, Dec 1, 1:01 AM CST
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Community Center F.A.Q (Last Updated: 2024 Nov 30 3:10 am)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: Problem using Firefox on forum
DrMCClark ( ) posted Tue, 25 April 2006 at 5:18 PM · edited Thu, 14 November 2024 at 4:30 PM
Is it me or is anyone else having problems using Firefox on the forums?  The "text editor" window stopped working or something.  It was ok a week or so ago, but I don't think it had this fancy-shmancy interface.
slinger ( ) posted Tue, 25 April 2006 at 5:28 PM
If you look to the far left of the text input window, at the top, you'll see a tiny triangle with no explanation of what it does.  Click on that and the "fancy-schmancy" bit will roll up and out of sight.  It's just to the left of where it says "Style" in case your eyes are as bad as mine. ~lol~
I'm on Firefox and have had no problems though, with the options tab open or closed.
The liver is evil - It must be punished.
DrMCClark ( ) posted Tue, 25 April 2006 at 7:25 PM
No, unfortunately, that doesn't seem to work.  On my Firefox, the entire "Body" box does nothing, regardless of whether I close the triangle or not.  Is it a Java applet?  Maybe I buggered my config...
DrMCClark ( ) posted Tue, 25 April 2006 at 7:34 PM
Ok, it's back now.  I had to reinstall Firefox.  Don't know what that fixed....
Faery_Light ( ) posted Tue, 25 April 2006 at 9:28 PM
No probs with Firefox but I wanted to try Opera.
 So I installed the latest stable version and it gives probs.
Even though I was signed in to all forums it refused to let me in the Merchants forum. Wouldn't even show that forum. Got a message that was a restricted area and I needed to log on. So I tried to logon and the MP window opened insted. Tried several times and same thing. And, yes, I am a merchant.
So I'm back to Firefox because it lets me increase the text as large as I need it.
Acadia ( ) posted Tue, 25 April 2006 at 10:15 PM · edited Tue, 25 April 2006 at 10:20 PM
I had problems initially. I had thought i had the current version of Mozilla-Firefox but it turns out that it wasn't updating itself like I had set it to do.  Getting the most most current version of the program fixed it.  It's definitly something java related which the new version seems to fix.
starmage ( ) posted Wed, 26 April 2006 at 8:09 PM
Well I had some problems with Netscape 7.....
Switched to Firefox but I've stillg ot the same or similar problems.  My whole window goes white and Firefox gets stuck.  This seems to happen mostly when I have a slow connection.  I have noticed that turning off my Instant Messengers etc has removed these issues.
It might be that a number of javascripts are trying to load simultaneously on the forum pages and if your connection is not top flight then it can get confused and stuck.
Only your mind limits yourImagination. Let it free.
mylemonblue ( ) posted Mon, 01 May 2006 at 10:23 AM
" Well I had some problems with Netscape 7.....
Switched to Firefox but I've stillg ot the same or similar problems.  My whole window goes white and Firefox gets stuck.  This seems to happen mostly when I have a slow connection.  I have noticed that turning off my Instant Messengers etc has removed these issues. "
I just had that firefox problem on a wide open cable connection minutes ago. It went all white, froze up, and task manager couldn't kill it. I realy had to force kill the thing. It's a frequent problem. This is happens on two separate PCs.
My brain is just a toy box filled with weird things
X-PaX ( ) posted Wed, 03 May 2006 at 10:44 AM
I've just tested with Firefox and I've got the same problem.
Now the good news: I've solved it.
I am using the very useful Firefox extension named NoScript.
Because this Text-Editor is a Java Applet it was not shown. So I allowed Renderosity to use script and everything works.
X-PaX
SiteMail
→ [ www.3dspots.de ]   |   [ www.cwhp.de ]
TrekkieGrrrl ( ) posted Thu, 04 May 2006 at 12:40 PM
Great that you found a solution :o)
I've been using Firefox from the start of the new forum (and before that) and I haven't had any problems. As a matter of fact I have ore prblems at work where I'm forced to use IE -  I get the double line space on enter there...
modus0 ( ) posted Fri, 05 May 2006 at 3:24 AM
X-PaX, would the script prevent the problem in the attached image from happening?
It doesn't happen much, but when it does, it's rather annoying.
:cursing:
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
