Sat, Nov 23, 5:16 AM CST
Subject: Penelope pixling problem need desperate help.
darthbobvilla ( ) posted Sat, 13 May 2006 at 6:23 AM · edited Fri, 25 October 2024 at 1:50 PM
HI all.
I got the penelope pixling kit some time ago and it was working fime...i had to redo my pc a while ago and i reinstalled everything...
Now when i work in poser with aiko and the deformer set  nothing happens...i tried like a 100 times easy to try the step by step instructions of wyrmmaster and nothing works...
I load aiko 3, then i go to props and apply the mdd set....i go to pose and i apply half elfing setting but when i do this all the remotes disappear for some strange reasons...i still continue and i go down and i zero out aiko cause i don't like the elfling look....i apply the tweaks i want to the body of aiko...
I load clothing and conform as instructed then i apply the instant cloth feature in the pose section wich should adjust the clothes to the figure i made...but to no avail no matter what i do the clothes do not want to "mold" to the figure.
I used to do the steps above with no problems and it worked fine. I just want to bang my head because i need the clothes to adjust to my figure and it worked before and now it ain't...can somebody give me suggestions on what could be the problems and remedy for this situation..
i don't know if i am doing somethign wrong maybe i am not applying something i used to apply ...
please need help bad or help with another way to adjust clothes properly...
cheers
meselfr ( ) posted Sat, 13 May 2006 at 9:35 AM
I just used her the other day... without issues..
Load A3
Apply Magnets
Apply Pose (1/2 Elf or Elfling)
Add Clothes
Conform Clothes
Select Clothes
Apply A3 clothes setup pose file (making sure to pick the right one)
hide parts and cleanup face (prefer my one as well)..
which sounds a lot like what you did.. :)
darthbobvilla ( ) posted Sat, 13 May 2006 at 12:05 PM
got it to work now
that is what i kinda don't like about the MDD sets you have to work with them in a VERY SPECIFIC way for them to work...
thanks i knew it was something simple i just could not get my nogin in it properly..
cheers
