Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
I would think that the Infinite Plane would not be able to take a Displacement map, so Carrara changes it into a finite plane so it can handle the math. Otherwise it would have to add 'infinity' to all the calculations, and that would crash the machine.
Not so much a bug, but an impossible request that gets converted into something it can handle.
A second attempt with some refinements, most notably, to increase the Fresnel property of both Reflection and Transparency of the shader to almost 100 - it gives a much more realistic colouring. Also increased the Reflection to about 90% or more - some recent "research" i.e. being at the coast revealed how reflective seawater is.
Had to play around with the Roughness and Offset terrain settings quite a bit, but I'm quite pleased with the result.
Also, the boat was too large and wrongly placed - it now looks correctly scaled.
Does anyone know how to attach a scene to a post, as they get rejected as "unknown file extension" or something like that.
R
Actually, that's not altogether true... you can attach a different kind of file, just change the extention, (i.e. ".car") to a supported extention type, (i.e. ".txt") and then you can attach it to a message here. Just let folks know what extention it's supposed to be and your all set.
Quote - You're only allowed to attach images in the forums. If you want to provide a .car file or shader, you'll need to host the file on your webspace and post a link to it here or you can post the link in the Carrara free stuff area.
Irene
I believe text (including html) is the only non-image file type you can attach. You're not supposed to be using the forums for file sharing for obvious reasons. If it is now allowing various other files to be attached, I'll have to check with the programmers. I don't think that was an intended change.
Irene
Irene-
It was not a change, you used to be able to do it no problem....
File exchange helps many people out here who get assistance from others by sharing the file that's causing a problem, or sharing a solution to a problem.
I think that IS within the spirit of this and other forums. If you disagree, then let's start a new thread and open this idea up to the community. I think it's important to leave this option open.
Thanks! Here's the scene - 12K. Right click on the red "x" above, and select "Save Target As ..." and change .jpg to .car.
To forum moderatorssite hosts - I'm not being funny here, but I can't even upload it to the "Free Stuff" area without posting it on the web first. Why isn't it possible to upload files related to this newsgroup e.g. shaders, scenes - there is a lot to learn from each other? A previous poster said filesharing wasn't enabled "for obvious reasons" - what are those in this context?
I know this is a free forum so can't complain, but it seems to go against the spirit of the website to disallow filesharing.
Thanks
Richard
There are a number of reasons for limiting file attachments. 1) Since attachments aren't checked and someone could upload anything, it protects both members and the site from malicous, against the TOS, and etc. type files being hosted here. Or at least attempts to. 2) Same reason folks are limited to one upload per day in the galleries and free stuff items need to be hosted off site. File space is not infinite, it costs money, and the forums were not originally meant to be used as free storage space.
Correct me if I'm wrong Mark, but I doubt anyone will complain about the occassional file_with_extension_changed thing you are doing now. It's probably not a big deal in the Carrara forum since most folks seem to want to only help eachother and want to share pretty small files. However, other forums have a bigger potential for abuse. Anyway, if you need a place to host or store files, there are free alternatives.
Irene
VistaPro Forum Coordinator
Irene-
I understand that. Again this is a free forum and I'm not here to rock the boat, just to share what I've got. After all, it was someone on this forum who shared with me about using a fractal terrain to create water, and in turn I'm passing along some refinements I'd made.
Will think of another way to host files from now on.
Thanks
Richard
Quote - Thanks! Here's the scene - 12K. Right click on the red "x" above, and select "Save Target As ..." and change .jpg to .car.
Thanks Richard for posting the file. It appears I was on the right track... I was following Patrick's setup but my water was too rough. After looking at your file I realized all I need to do is scale up the terrain to smooth it out. Thanks again.
Chucker
Ah-ha! That was my problem too. The terrain size in your scene is 5000mi x 5000mi. Previously I was using 100mi x 100mi which I'm pretty sure is what is shown in Patrick's scene shot. Thanks!
If you need temporary file hosting, I have web space that I don't use. E-mailing me a file and then waiting for me to send you the link isn't as expediant as hosting it yourself. But I know some folks really detest using the free services due to popup ads and whatever. I'm happy to provide a possible alternative if needed. Now I'm off to go do something with that water. Thanks again! :)
Irene
Irene-
I've often found that infinite planes behave like "finite" planes i.e. I can see the edges. e.g.
Now try this
The Infinite Plane has become a normal plane!
Any thoughts? Am I missing something or is this another bug?
Thanks
Richard
