Fri, Nov 29, 12:45 PM CST
Subject: OT: Looking for a program that will unzip multiple zipped files
jhustead ( ) posted Mon, 28 August 2006 at 5:48 PM · edited Fri, 29 November 2024 at 9:56 AM
I had this thought running through my mind the other day about what would happen if I had to reload all of my zipped files again. I thought oh my goodness I have about a thousand zip files for just Poser alone. So do you know if there is a program that will unzip multiple zipped files at once? Any input would be appreciated.
Thanks,
James a.k.a. jhustead
MachineClaw ( ) posted Mon, 28 August 2006 at 5:59 PM
WinZip Command Line Support Add-On free for Winzip Pro.
I just use the command line of Unzip *.zip .
I foget what /FLAG I use, I have a batch file setup I use for multiples.
you can also select multiples in file explorer right click and hit extract.  Then just hit the YES to all.  Depends on how ya are setup.
wheatpenny ( ) posted Mon, 28 August 2006 at 6:46 PM · edited Mon, 28 August 2006 at 6:47 PM
Site Admin
WinRar does that. Just select all the zips then right click and among the options are "extract here", "extract each archive to a saparate folder", etc...
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Angelouscuitry ( ) posted Mon, 28 August 2006 at 6:56 PM
Attached Link: Stuffit Expander
Stuffit Expander is the program you're looking for.  It will open a window you can Drag and Drop 100's if .ZIPs into, all at once, and it will get right to extracting one after the other automatically.
I think it comes with Stuffit Deluxe too!
Angelouscuitry ( ) posted Mon, 28 August 2006 at 7:08 PM
martian_manhunter!  Where did you come from??  WinRaR does WHAT?!?!?  I have to go check this...Ou...Wow...that was much better!!!
You just select all of your .ZIPs > Right - Click, and Select Exptract to Seperate Folder!  And it even maintains the name of each .ZIP through to the folder!!  Stuffit wo'nt do that, and there's no Opening the Expander window/application!
O' Boy, "And "WinRar" retains it's title as My Favorite Archiver!"
Acadia ( ) posted Mon, 28 August 2006 at 7:16 PM
Attached Link: http://www.webmasterfree.com/unzip.html
I use  a free program called "Unziplify".  Just put the zip files into the base level of one folder. Right click the folder, pick "Unziplify" and it unzips all of the zips in that folder. When you open the folder all of the unzipped contents are in a folder inside titled "Unziplify".
Acadia ( ) posted Mon, 28 August 2006 at 7:19 PM · edited Mon, 28 August 2006 at 7:20 PM
Quote - WinRar does that. Just select all the zips then right click and among the options are "extract here", "extract each archive to a saparate folder", etc...
Geez! I've had Winrar for sometime and have never noticed that.
I also see now that if you select multiple zip files you can do the same thing with Winzip.
Awesome.
jhustead ( ) posted Tue, 29 August 2006 at 9:06 AM
Thanks for your replies. I'll go check out those programs. Thanks again!
James
JenX ( ) posted Tue, 29 August 2006 at 1:11 PM
Also, Zip Exploder (don't have the link offhand, I'm at work) works well for unzipping multiple files at once ;)
nruddock ( ) posted Tue, 29 August 2006 at 8:05 PM
Attached Link: http://www.7-zip.org/
7-Zip has a command line version.
