Wed, Feb 26, 7:05 PM CST
Subject: Impoted Mesh not displaying correctly
Touchwood ( ) posted Wed, 30 August 2006 at 8:46 PM · edited Wed, 26 February 2025 at 3:52 PM
Can anyone tell me why when importing any kind of mesh object into Bryce, it displays like the attached image? Objects created inside the program display correctly.
Dann-O ( ) posted Wed, 30 August 2006 at 10:12 PM
Turn up your wireframe resolution. I have mine at max. that should do the trick. The Adjustment i son the right hand side. Look sliek 3 boxes and an arrow.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
Touchwood ( ) posted Wed, 30 August 2006 at 11:34 PM
Thanks but the resolution is already up for all three states. The imported meshes do render correctly and display correctly in other programs.
AgentSmith ( ) posted Thu, 31 August 2006 at 3:16 AM · edited Thu, 31 August 2006 at 3:18 AM
Yeah, Keep your Selected up, but turn down Motion & Static.
Even then, when you have a high poly count mesh, you may at times have to do the Ctrl+Click and re-select it (even though it is already selected), and that will make it look normal again.
I think this is due to just a ton of polys being displayed and your video card needing a little help. I myself have what is probably considered an obsolete video card (GeForce FX5200), and I have to re-select high poly meshes once in a while to make them appear "back".
Touchwood ( ) posted Thu, 31 August 2006 at 8:49 PM
Thanks, turning up the selected to max done the trick. Didn't think there were so many polys in such a small (looking) object.
Stephen Ray ( ) posted Thu, 31 August 2006 at 11:42 PM
I usually just turn the wireframe res up high while I'm placing the imported mesh into position ( so I also have it high for motion too ). But once it's in place I either turn down the wireframe res. or turn it into bounding box display on the objects attributes menu. This helps keep the work flow running smoother.
Stephen Ray
