Sat, Nov 30, 2:56 PM CST
Subject: I dunno where to get a p4 eyebrow transmap?Anyone got a Clue?
Binx ( ) posted Fri, 20 April 2001 at 2:47 PM ยท edited Sat, 30 November 2024 at 2:44 PM
I dunno where to get a p4 eyebrow transmap?Anyone got a Clue? Probably a silly question.....but i know i have a lip bump and eyelash transmap.....is there a decent skin bump out there for p4 females? Any links or help would be helpful..... Thanx alot.....Binx
Kevin ( ) posted Fri, 20 April 2001 at 4:06 PM
Digital Babes, I think.
sama1 ( ) posted Fri, 20 April 2001 at 5:53 PM
Attached Link: http://morphs.bbay.com/
There is a full eyebrow prop at morph world under the downloads the the Eve stuff. Not sure what effect you are after but a prop sounds like the trick. You may need to modify the transmap files to get the look you are after. I hope this helps, Sam
Ghostofmacbeth ( ) posted Fri, 20 April 2001 at 7:18 PM
If you use a transmap on the standard eyebrows you will get a hole in the head S But the prop has one that works ... As far as skin bum. I usually use the one that comes with poser for most things. It works pretty well. Kind of unlike the texture maps S
Kevin ( ) posted Fri, 20 April 2001 at 10:22 PM
Attached Link: http://digitalBabes2.com/dload.html
Oh well, digitalBabes2.com/ has a lashes transmap, not a eyebrow map. Sorry.
