Sat, Nov 23, 4:29 PM CST
Subject: HELP ME PLEASE !!!
PrezPerkz ( ) posted Sat, 21 April 2001 at 1:01 AM ยท edited Sat, 23 November 2024 at 4:22 PM
Can anyone help me, i need to do a pic like this one with the same hair and a bandana. ANY tips or help will be useful..... Thanx Perks
TygerCub ( ) posted Sat, 21 April 2001 at 7:44 AM
That hair looks like a modified woman's hair prop I've seen in other pictures. Look in the store or freestuff? The bandana looks to be a texture map applied directly to the skin texturemap and carefully matched to the hair. Gonna be some work to make that fig... good luck
hauksdottir ( ) posted Sun, 22 April 2001 at 1:17 AM
I think Maclean did a "hippy headband" a few months ago. If the tail is transmapped or made invisible, it would be better than painting a bandana onto the skin. For the hair use a woman's style or the Caesar cut on the Costume Shop CD, with a few morphs or magnets to get it to stick out. You can also select the top of the head, type "hair" on your keyboard and play with the spikes. :) (This is an undocumented feature of Poser.) Carolly
PrezPerkz ( ) posted Sun, 22 April 2001 at 1:21 AM
ok thanx Carolly, But were would i find the costume shop CD and the hippy headband (sorry if these are dumb questions i am REALLY new to poser)? And what do you mean select the top of the head? Thanx for putting up with me ;) Perks
PrezPerkz ( ) posted Sun, 22 April 2001 at 1:22 AM
.....Also bear in mind i am only 15 therefore have no chance of buying anything online ;) Perks
hauksdottir ( ) posted Mon, 23 April 2001 at 12:26 AM
Hi, I usually only slip into the Forums once a night, so I can't reply immediately. Sorry. The hippy headband can be found at 3dCommune free stuff and Poser Forum Online fun stuff, but I couldn't find Maclean's work here. It is a free download, from a guy who has made lots of useful and different props. The Costume Shop CD is from DAZ, and has to be purchased (it is well worth the price when you get to the point of buying stuff), but there are lots of hair props in the various free areas. Looking under "hair" alone will probably only result in supermodel stuff. You may wish to find a fighter or such character (search in the"characters" sections) and borrow the hair for your model. The 3dcc has mostly comics characters, but villains often have scruffy hair. Also check out morphworld (part of bbay). I don't know if Traveler has hairmorphs, but you'll want to make your fighter look less pretty than the basic P4 Dork. Thickening the jaw and nose will be a start. As for that "hair" command... when you are in Poser you click on a part of the body in order to move it, right? For example, use the hand camera and then click on part of the hand in the view window. A set of dials will come up for moving and scaling it. That part is selected. Now type the word "hair" on the keyboard and hit [enter]. You should get a pop-up box full of options to play with. It isn't subtle at all... so you won't get silken fuzz on the palm of your vampire, but this might give you the spikiness you need. Selecting a portion of a bodypart is harder: you'll have to use the grouping tool to select polygons, and I'd suggest reading the manual to learn about spawning parts and grouping them. Hope this helps, Carolly
