Community Center F.A.Q (Last Updated: 2024 Nov 29 5:48 am)
Terry, Your browser version is out-of-date. The latest version of Netscape is 8.1.2. Netscape versions below 8.0 had a bug in them adding every iFrame loaded in a page to the browser's history, which is that is causing your problems. Upgrading to 8.1.2 will fix the problem you are having. Hope that helps, N
-Nicholas
Two different computers, one W2K the other XP, both using Netscape 7.2 as the browser, same problem. Only at Renderosity does the browser's "back" button not work after I've opened a message thread to read, for example. Most often the progress bar at the bottom of the browser window never quite gets all the way done ("Waiting for www.renderosity .com"), and I have to select the "Retrun to top of forum" option to escape the open thread.
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
